What did you do at work today?
   / What did you do at work today? #243
At work today I dispatched a lot of trucks got yelled at about the new ELDS got yelled about the DPF and regens then poured my first cup of coffee.
Plowed the deer food plot yesterday.
What are you planting? Around here that's usually oats in October I think.
I planted buckwheat Labor Day for hunting over. Plowed it Saturday so it can lay out until next summer when I plant something else for deer season. Buckwheat worked okay but first frost got it and it was done.
The disk was over at the farm and I brought it home when I brought the plows back is the only reason it is on the trailer.
   / What did you do at work today? #248
Yessir. Laminating. The wood is actually submerged in the hot water tank.
They for decoration or being used?
I have done a bit of steam bending and bend three time to break down the lignin so it doesn't come back, bend the way you want then the opposite3 way then back the way you want, found it reduces a lot of movement in the future.
My steamer was really sophisticated, a 2 litre olive oil tin with a copper pipe soldered on sitting on a gas burner, plastic water pipe with a rag stuffed in each end, wide enough to take whatever I was bending, looked pretty rough but it worked well.
   / What did you do at work today? #249
They are for use on saddles. Ours is very sophisticated :laughing:. A stainless steel tank about 3'x4' and 3' tall with a heating element. Submerge the laminates til hot enough to bend.
Been making a miniature Woods bushog, got to make the gearbox, blades, etc now.
2018 CAT 336FL EXCAVTOR (A55745)
2018 CAT 336FL...
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 68in Dual...
2001 CATERPILLAR 420D BACKHOE (A52707)
2001 CATERPILLAR...
Yamaha Cart (A55853)
Komatsu WA180-1 Wheel Loader (A47477)
Komatsu WA180-1...
SKIDDED MIXING UNIT (A55745)
SKIDDED MIXING...
