What did you do at work today?
/ What did you do at work today? #243
At work today I dispatched a lot of trucks got yelled at about the new ELDS got yelled about the DPF and regens then poured my first cup of coffee.
Plowed the deer food plot yesterday.
What are you planting? Around here that's usually oats in October I think.
I planted buckwheat Labor Day for hunting over. Plowed it Saturday so it can lay out until next summer when I plant something else for deer season. Buckwheat worked okay but first frost got it and it was done.
The disk was over at the farm and I brought it home when I brought the plows back is the only reason it is on the trailer.
/ What did you do at work today? #248
Yessir. Laminating. The wood is actually submerged in the hot water tank.
They for decoration or being used?
I have done a bit of steam bending and bend three time to break down the lignin so it doesn't come back, bend the way you want then the opposite3 way then back the way you want, found it reduces a lot of movement in the future.
My steamer was really sophisticated, a 2 litre olive oil tin with a copper pipe soldered on sitting on a gas burner, plastic water pipe with a rag stuffed in each end, wide enough to take whatever I was bending, looked pretty rough but it worked well.
/ What did you do at work today? #249
They are for use on saddles. Ours is very sophisticated :laughing:. A stainless steel tank about 3'x4' and 3' tall with a heating element. Submerge the laminates til hot enough to bend.
Been making a miniature Woods bushog, got to make the gearbox, blades, etc now.
Recently got done making a miniature Ford blade like the real one.
/ What did you do at work today? #252
very nice
/ What did you do at work today? #253
I’m reviewing some timber harvest and thinning treatment prescriptions and other plans for the upcoming field season. Looking at the white landscape out the window and wanting to get back to the field when accessible.
/ What did you do at work today? #256
Good that you added the zerk on the rotary cutter guide wheel...
Should last for more than 15 years if you keep it greased!
/ What did you do at work today? #257
Fun times. I work for a pump rental company. So it can get interesting. Had a customer beg me to go look some equipment that they own out on a jobsite.
Drove 2.5 hrs one way just to tell their employee to fill the unit up with hydraulic fluid and to get it in deeper water.
The employees boss was pretty hot. Bet he went through the roof when he got my bill 😏😏😏😏
Had a hydraulic submersible that was locked up. Guess the customer didn't realize that rope wasn't something that it could handle.
Did get my 300 gallon tote of DEF fluid in. Held off hooking up the pump till I could get some more hose for the dispenser. I wanted to be able to reach outside with the nozzle incase the bay had equipment in it.
We are getting DEF fluid for half the price of what it costs at the.pump at the truck stop.
/ What did you do at work today? #258
Looks good now but wait until the always present spillage coats everything with white powder. DEF is liquid urea and di-ionized water and when the water evaporates, the crystalized urea remains.
Gearbox and PTO shaft are made, now to make a shield for the shaft. The gears came out of an angle head for a Dremel tool.
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
UNUSED RAYTREE RMBD72ST-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
2003 Big Tex 10PI...
Schulte SBW800 Rock Windrower (A61307)
Schulte SBW800...
