Kubota RTV 1100 Deere 6x4
   / Kubota RTV 1100 Deere 6x4 #31
A six wheel rig is real hard on turf as well. Got a 6x6 Polaris donated to the FD because it was Tearing up the guys lawn. We had plenty of problems with it even though it was a low hour one owner machine. We ended up getting a Honda Pioneer, quite an upgrade . I have a RTV 900 but don’t plow it, a true true work machine.
   / Kubota RTV 1100 Deere 6x4 #32
The Gator is a different machine than the 6x6 Polaris. My father has been through four Polaris ATVs in the same time frame I owned my 6x4 Gator. (1) 6x4, (2) 6x6 and (1) 4x4. The tires on the Polaris ATVs are a bit more aggressive and narrow so I can see where the lawn could get torn up. I never tore up any healthy lawn with my 6x4 Gator plowing or otherwise as the tires are less aggressive and wider. It has differential lock but it is engaged with a lever in the cab and used very infrequently. The other comments about turning radius may also have something to do with it. You will not turn on a dime with the 6x4 Gator but I can turn sharper than a pickup truck. I have plowed snow with a pickup and hate the fact I cannot see the plow at all times. Spoiled with the Gator being right on top of what I am plowing.
As for heat, working with my neighbor we built a custom exhaust on the 6x4 Gator to run it through the cab behind the seat and up over the cab for two reasons. 1. Plowing snow is 50% backing up and with the exhaust out the back, it would come right into the cab through the orifice for shifters and cables. With it overhead, the exhaust was always above the cab forward or backward. 2. Heat, my gator does not have the water heat/fan in it and I did not want to spent the extra $500 and give up my glovebox so by running it through the cab it heated the cab just nicely and allowed me to plow in a t-shirt.
Again, I plowed my driveway for 15 years using this method and not saying it is the best for a commercial operation but was a lot of fun. The OP is a Kubota man and would probably be disappointed with green and yellow polluting the orange glow in his shop. My suggestion is still to go with the Orange for your situation.
   / Kubota RTV 1100 Deere 6x4 #33
I think they refer to the Polaris (at least some old 6 wheel models) ripping up turf because they had no diferential.
I started with looking for something cheap to plow big sidewalks, paths and small parking areas, but we all know how that goes- you start looking at other stuff and before you know it, there goes the budget. :rolleyes:
   / Kubota RTV 1100 Deere 6x4 #35
Sadly, it does.
Found a unit with tracks! Wonder about the advantages/disadvantages?
Advantage: traction, ground compaction
Disadvantage: cost, maintenance, pavement travel?
Maybe a separate thread?
   / Kubota RTV 1100 Deere 6x4 #38
Do you have any pictures of yours? Do you mind sharing them if you have time to upload?
Thanks
Pics from the day I got it--Still looks the same
   / Kubota RTV 1100 Deere 6x4 #39
Thanks for the pics Tim. I really like my open station 900. Most reliable machine I've ever owned.
They are so ugly that they are beautiful. :D
P.S. Wish I had your cab this time of year!!!!
   / Kubota RTV 1100 Deere 6x4 #40
It is ugly, I'll give you that :)...Wish I had an open station for the summer and this for the winter..I don't need AC but without roll-down windows it's a must...A little too spendy to have two of them.
2008 Ford F-250 Crew Cab Pickup Truck (A51692)
2008 Ford F-250...
2007 CHEVROLET SILVERADO K150 CREW CAB TRUCK (A51247)
2007 CHEVROLET...
2018 Ford F150 4x4 Pickup Truck (A51692)
2018 Ford F150 4x4...
2005 Fella-Werke SM-320 (A50123)
2005 Fella-Werke...
UNUSED 16" AUGER (A51248)
UNUSED 16" AUGER...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
