K5lwq
Elite Member
- Joined
- Aug 6, 2017
- Messages
- 4,900
- Location
- Mineola, TX
- Tractor
- Kioti LK2554, Branson 4815C, Satoh Beaver, Speedex
Mine tank is in the same place and the tractor is one of the early LK series. 96 I believe. I am sure yours should have the fuel pump but for whatever reason it is not there. I think if you can find where it bolts, should be exactly where mine is, and add the pump your problem should go away.
As far as I know they did not change anything till the LK3054XS. There is a lot different on the XS.
I should add that I had a problem with rust in my tank. I drained it, used paper shop towels to mop up remaining fuel and then used a shop vac to get the loose stuff out. Before I did that fuel filters were clogging pretty fast. No problems so far after cleaning tank.
