MF GC1720 4WD Front Axle Hydraulic Oil
   / MF GC1720 4WD Front Axle Hydraulic Oil #1
johnnylee1945
Liberty, Idaho
2018 MF GC1720
2018 MF GC1720-4WD...
A newbie here... Silly question, why would the Hyd. Oil in Front axle be dark colored after only 55 hours? I have been using 4WD to push snow since Dec. But it seems awfully dark...???:confused:
Thanks in Advance.
   / MF GC1720 4WD Front Axle Hydraulic Oil #2
Wouldn’t be hydraulic oil in the axle; should be basically gear oil I would think. Check your manual for the specs
   / MF GC1720 4WD Front Axle Hydraulic Oil #3
It's hydraulic oil...
Mine was kinda dark too. Who knows why.
Didn't worry about it and put new in. Still going strong.
Thanks seville009 , but it is hydraulic oil, same as the transmission and rear end (hydrostatic).
Snobdds, I guess that is about it... I did the same. Put new end and will not worry. Thanks!
   / MF GC1720 4WD Front Axle Hydraulic Oil #6
Probably dark from all the cutting oil at the factory. That is why they typically recommend changing all the fluids at 50 hours....flush everything out.
   / MF GC1720 4WD Front Axle Hydraulic Oil #7
My 2009 GC2410 called for MF Permatran lll for the front axle, but I decided to use this:
AMSOIL SYNTHETIC GEAR LUBE SAE 80W-90
KC
   / MF GC1720 4WD Front Axle Hydraulic Oil #8
The front end lives an easy life from a lubrication stand point. If you are in a cold climate lean toward the hydraulic oil and in warmer climates the gear oil is probably fine. The oil in the front end of a tractor is a non issue.
Cat TH407C Telehandler (A53472)
Cat TH407C...
UNUSED Artificial Turf Grass (A53117)
UNUSED Artificial...
SOFF-CUT GX-4200 WALK BEHIND SAW (A55745)
SOFF-CUT GX-4200...
2019 Yongfu Scooter (A55853)
2019 Yongfu...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2006 APPA TL (A55787)
