MF GC1720 4WD Front Axle Hydraulic Oil
   / MF GC1720 4WD Front Axle Hydraulic Oil #21
   / MF GC1720 4WD Front Axle Hydraulic Oil #22
Old school ways die hard...
And maybe with good reason, in a gear box with bevel and spur gears I do believe that the shear additives in gear lube are better then the shear additives in hy tran.
They may well work fine under normal conditions and loads I prefer more of a cushion, you do as you wish.
   / MF GC1720 4WD Front Axle Hydraulic Oil #23
+1 for old school ways, Synthetic Gear Lube for me.
KC
   / MF GC1720 4WD Front Axle Hydraulic Oil #24
I was amazed at how long it took small engine mfgrs. to spec multi grade oils. I still wonder why DR stays with straight 30 hd when DR is located up in Vermont and a lot of their products are winter usage items. None of my half a dozen manuals spec anything else (recalling) and in their service kits, that's the oil listed.
2014 LAMAR TRAILER (A52472)
2014 LAMAR TRAILER...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2020 KENWORTH W900L DAY CAB (A52472)
2020 KENWORTH...
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
