MF GC1720 4WD Front Axle Hydraulic Oil
   / MF GC1720 4WD Front Axle Hydraulic Oil #21
   / MF GC1720 4WD Front Axle Hydraulic Oil #22
Old school ways die hard...
And maybe with good reason, in a gear box with bevel and spur gears I do believe that the shear additives in gear lube are better then the shear additives in hy tran.
They may well work fine under normal conditions and loads I prefer more of a cushion, you do as you wish.
   / MF GC1720 4WD Front Axle Hydraulic Oil #23
+1 for old school ways, Synthetic Gear Lube for me.
KC
   / MF GC1720 4WD Front Axle Hydraulic Oil #24
I was amazed at how long it took small engine mfgrs. to spec multi grade oils. I still wonder why DR stays with straight 30 hd when DR is located up in Vermont and a lot of their products are winter usage items. None of my half a dozen manuals spec anything else (recalling) and in their service kits, that's the oil listed.
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52748)
2020 New Holland...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2012 International 4300 Reefer Truck (A52748)
2012 International...
