JD 5303 Tie Rod Ends
   / JD 5303 Tie Rod Ends #11
I have seen home made u-joint boots from leather. Leather, laces tie-raps and grease. As long as it keeps the dirt out it's fine.
New joint will come with a new boot and clamps.
I appreciate the thorough description of the replacement and function of the part. That all made sense.
Believe this would be the part(s).
Looks like the part #6 would need to come off to get to the part to be replaced.
   / JD 5303 Tie Rod Ends #16
5 is the radial joint but yes, 6 needs to be removed from the outboard casting to remove and replace 5. Don't forget the boots and clips either. The design is pretty much standard across all makes with hydrostat steering.
   / JD 5303 Tie Rod Ends #17
I'd be cautious about that in as much as sealing a home brew boot would be difficult and the neoprene boots aren't that expensive anyway. They do require disassembly to install but you are gonna replace the radial joint anyway.
30pc. 16ft.x 3ft. White Metal Roof Panels (A55758)
30pc. 16ft.x 3ft...
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
UNUSED RAYTREE RMSC78 - 78" SOIL CONDITIONER (A54757)
UNUSED RAYTREE...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55218)
2024 BCL...
34015 (A55787)
34015 (A55787)
