JD 5303 Tie Rod Ends
   / JD 5303 Tie Rod Ends #11
I have seen home made u-joint boots from leather. Leather, laces tie-raps and grease. As long as it keeps the dirt out it's fine.
New joint will come with a new boot and clamps.
I appreciate the thorough description of the replacement and function of the part. That all made sense.
Believe this would be the part(s).
Looks like the part #6 would need to come off to get to the part to be replaced.
   / JD 5303 Tie Rod Ends #16
5 is the radial joint but yes, 6 needs to be removed from the outboard casting to remove and replace 5. Don't forget the boots and clips either. The design is pretty much standard across all makes with hydrostat steering.
   / JD 5303 Tie Rod Ends #17
I'd be cautious about that in as much as sealing a home brew boot would be difficult and the neoprene boots aren't that expensive anyway. They do require disassembly to install but you are gonna replace the radial joint anyway.
2012 Honda Accord Sedan (A55758)
2012 Honda Accord...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2012 CATERPILLAR D6T XW HI-TRACK CRAWLER DOZER (A51406)
2012 CATERPILLAR...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2003 Honda Element SUV (A55758)
2003 Honda Element...
