I need a rear snowblower for my GC1715
   / I need a rear snowblower for my GC1715 #11
I really liked my rear facing snowblower. I love my Rear Pull Snowblower.
   / I need a rear snowblower for my GC1715 #12
I have an MK Martin meteor sb54 on the rear of my kioti cs2210. Works well with my tractor and is well built. Been running it 3 years now trouble free so ive been happy with it.
Kioti cs2210 blowing snow - YouTube
   / I need a rear snowblower for my GC1715 #13
I was considering getting one of these but having a small tractor I dont know how well it would work being that you have to drive through the snow first before the blower gets to it. Around here at times ( today actually) we get drifts that can be 2-3 feet high and I'm just not sure it's the answer with a small machine.
   / I need a rear snowblower for my GC1715 #14
Just as an FYI, I leave my loader on all the time. I remove the bucket or forks, raise the arms high enough to see under them and hydraulically lock the them in position with a high pressure ball valve i installed on the raise hose. Then I can unhook all 4 hydraulic lines and use the joystick to operate the front mount blower. Takes a couple minutes to remove the blower and reconnect the lines. Not ideal, but you cant beat a front mount blower.
   / I need a rear snowblower for my GC1715 #15
EA06870B-295A-4BA8-8360-C6C739DA17E5.jpeg6E2C98D4-4F57-430D-AEE3-BA4B259A64D8.jpegE66ABA37-8980-43EF-9A89-FEA7860B741F.jpeg
   / I need a rear snowblower for my GC1715 #16
Here's another way to hold the loader arms up.
   / I need a rear snowblower for my GC1715 #17
That is a better way, for sure.
   / I need a rear snowblower for my GC1715 #18
For a SCUT, that's not a bad plan. Put some magnetic mount LEDs on the loader frame, and you'd really have something.
   / I need a rear snowblower for my GC1715 #19
I cannot use a rear blower that must be operated in reverse due to neck issues, so I went with a pull type blower. So far it has worked well. I have an old cheap $100) back blade mounted on a SSQA to push snow and back blade with.
Driving over a foot of snow is no issue, but I do not get the 2-3' drifts you have. If I had to deal with that, I would use the front blade to push them to a manageable height, or the FEL. Having the SSQA setup for the front blade is important to me as I use the FEL or pallet forks.
Driving in reverse is not fun so do some testing as suggested above.
My pull blower is a FarmKing and I am happy with it. It was $3000 less than a front mount for the LS4140 I have.
   / I need a rear snowblower for my GC1715 #20
I understand. But I need my FEL for my hobby Farm. Rear mount it has to be. Did the 1710 do fine? I don't care about looking back.
The 1710 did fine, it would be a bit better with about 100 lbs hanging off the front though, I never found a place for the weight with the loader on.
UNUSED FUTURE BS72 72" HYD BOXBROOM SWEEPER (A57193)
UNUSED FUTURE BS72...
WB Mower (A50120)
WB Mower (A50120)
LaneShark LS3 (A56469)
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
48in Farm Jack (A55852)
48in Farm Jack...
9202 (A50322)
9202 (A50322)
