How to transition to MIG?
   / How to transition to MIG? #1
BigBlue1
Elite Member
Middle MN
JD: 2520 & x758
I have been welding with stick as my only method for many years. Not that I'm good at it or have done it a ton, but I can make metal stick together passably. It doesn't look great and I wouldn't stake my life on the results but most of my projects are non-critical and they hold up fine. :)
Stick welding is a pain though, probably because I'm not that good at it. Sometimes it is hard to strike an arc. Probably using the wrong type of rod. And I probably should get a better helmet that is auto-darkening so I can see what I'm doing before I strike the arc randomly an inch away from where I'm supposed to be starting. I know I have some challenges overall. Going to work on those. My welder is an ancient (30-40 year old) Lincoln buzzbox. I think it is in decent condition but I guess it is possible that it may not be in tip-top form itself so that may contribute to my pains. I have replaced the leads and ends recently.
But I'd like to get into MIG welding. It seems like it may be a little easier to control things and not be as futzy as stick welding. Is this a reasonable thought? Does anyone have a pointer for someone who knows the general concepts of welding to get up to speed on MIG? Things like choosing fluxed vs. non-flux wire, what gas is needed, wire thickness to choose, wire speed, etc? I'd like to learn about it before buying a new welder.
Thanks,
Rob
   / How to transition to MIG? #2
Plenty of youtube videos out there.
The one tip I will say, if you haven't bought a welder yet, get one with the auto wire feed setting. Then you just set the temp and the welder will set the wire speed. Works for most applications until you might get into the thin sheetmetal stuff or something odd.
Look up the Millermatic 211. There are other brands with the same, but I found it to be very helpful for someone who is not a super experienced welder.
Thanks for the tip. Does the Hobart 210MVP have that auto speed capability? That's the one I've been eyeing. Seems like it is pretty capable and highly regarded and also only about half the price of the Miller 211.
Rob
   / How to transition to MIG? #4
This is a great topic. You should get a LOT of response. There are several Craftsman Welder Guys on here!!!
MIG is much easier to use than stick. Your technical questions can only be answered by knowing your expectations in regards to thickness of metal, etc.?
Hobart makes a nice affordable 140A MIG welder that will use gas/solid core wire or flux coated wire. I'm not pimping Hobart but they are readily available and expendables are easy to find. With that Amp range you'll probably use .030 wire.
This is just me now. I wouldn't buy a 110V MIG welder. Just like if I thought I needed a 30hp tractor I wouldn't buy a 25HP. Since you already are welding you have a need. Buy a brand name, 220V, 140A minimum, gas capable welder. You'll love it.
If Mark from Everlast gets in here he'll give you very logical, sensible advice whether you buy his brand or not.
Edit: I have a Miller 250 that I run .035 wire with 75/25 gas.
   / How to transition to MIG? #5
Rob
No. But has the dual voltage which is nice. I have used mine on 120 or 220 volt based on different occasions to use it.
I bought my 211 used, and never had an issue, but it was basically new when I bought it. Go to a local welding store, sometimes they do demo days.
   / How to transition to MIG? #6
Rob
   / How to transition to MIG? #7
I traded my Miller 180 millermatic to a guy for the Miller 250 I now have. Even trade. I was giddy. :)
With the millermatic feature I always had to bump up the wire speed just a pinch. And I wanted to weld thicker metal.
Thanks. I'm not looking for specific answers on those welding concepts, just the guidelines and knowledge needed to figure that stuff out as I encounter situations.
I'm not looking for an entry-level MIG. But also not a high-end unit. I want something capable of welding at least 1/4" steel and hopefully 3/8". I'm a guy that likes to go a little overkill but not wastefully so. Last thing I want is to buy something that I outgrow soon or that disappoints me when I need to do something. I have 220V in my shop for my stick welder but having a 110/220V capable one that can be portable to 110V sites would be a plus. That's why the Hobart 210MVP looks good to me.
Thanks,
Rob
   / How to transition to MIG? #9
Rob.
From what you say though I think you would greatly benefit from:
1 purchasing an auto darkening helmet
2 having an experienced welder go over technique and use of your current stick welder with you.
3 then by all means purchase a MIG welder as an upgrade if you wish.
Good luck
   / How to transition to MIG? #10
bigblue1 - i started as a kid on a lincoln buzzbox and have used 3 of them for years, one at my house, one at the farm and one at my buddies that i bought for him at his farm so we had a welder, I will say this, I LOVE stick welding outside of overhead or vertical, im not proficient with it. However give me a flat angle and boy it will be pretty.
Next, if you are doing farm welding like me - on rusty, painted broken farm stuff - stick is the way to go - you can do some with flux wire but if it is any thickness to speak of it will take a good sized mig and unless you get one with dual voltage it will not be very portable.
I am not as fond of the MIG for several, due to the nature of the tip they are harder to see the puddle, if you use gas your piece to be welded HAS to be clean AND you will not have good luck if there is any WIND to blow the gas around. Flux core is not subject to the wind and burns a little hotter than the gas mig.
That being said its much easier to product a lovely looking weld with a mig but i think a little more difficult to be sure of your penetration due to the fascination of such a great looking weld.
Not sure what kind of stick you are using in your buzz box but i can tell you w/out reservation the 7014 is the BEST rod to run in a lincoln AC225 box, i will make some amazing welds.
I HATE 6011, 6013 is mehhhh, 7018 stink even 7018AC rods, never tried to run a 6010 in a 225AC buzzer but they probably wouldnt run that well. 7014 is the only rod i run in my buzzers. Since moving to a idealarc 250 with ac/dc i love the 6010 in it, the 7018 are ok BUT they are a pain to start cause you have to whack the stick each time to start to chip off the flux that seals over on the end of it due to the nature of the rod.
Mig is great for thinner stuff than your AC225 is capable of so what you are trying to weld will determine what you want to look for with the MIG.
Mig is much more complicated to weld than stick. You have more variables such as prep, temp, speed, angle, wire vs gas, so as was mentioned to help you in that get one of the auto synergy/setting type
millermatic - autoset is their term
lincoln - 210mp
vulvan - omni 220
everlast - 211si is one
many options but just wanted to throw that out there - what kind of welding are your plans for? new? repairs? thick? thin? aluminum? cast?
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Cat CB24B (A60462)
Cat CB24B (A60462)
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
Case-IH 370 Steiger (A57148)
Case-IH 370...
