How to transition to MIG?
   / How to transition to MIG? #31
Have to remember that a mig starts cold. When doing thicker material with a stick, you can hold a long arc without metal transfer to warm up to welding temp.
   / How to transition to MIG? #32
I like having my Miller 140 (110V) with .024 wire and my Lincoln Power Mig 250 with .035. I don't have to change the wire on either machine when welding lighter or heavier material.
   / How to transition to MIG? #33
This thread really isn't about choosing a machine. I'm mainly looking to understand what the knowledge and technique info I would need to MIG weld, as compared to stick welding. As some have pointed out, wire speeds, voltages, rusty parts, wind, etc. are all factors with MIG that aren't the same as stick. Going to try to watch some youtube videos one of these evenings.
Thanks,
Rob
You will love MIG... it is easier than stick so you are ahead of the learning curve already. You will want gas and a wind block if you move outside your indoor shop. Grind and wipe your weld joints prior and go for it. I am pretty sure that once you give it a try it will come extremely fast. Practice pushing and pulling on horizontal and vertical and see the difference. I watched a bunch of YouTube vids but playing on scrap is the fastest way to learn. For YouTube, Jody's tips and tricks channel is superb.
The cheater charts that are on the inside cover of some machines (I have a Miller 211MVP transformer) make it really easy to dial in your settings depending on wire thickness, metal type, and thickness. the 'autoset' function if you have it, is usually very good. I tend to set from the chart and tweak the V and A if not super happy with the bead.
   / How to transition to MIG? #34
I used a Miller AC/DC box for decades. Made the shift to MIG a few years ago. It took about 15 minutes. I use the autoset on a Miller 211. I usually set it a bit higher than the dial calls for. I have used it on 1/16" to 1/2" steel. Have not touched the old AC/DC box since I got the 211.
   / How to transition to MIG? #35
I am an old SMAW fan as that is what I learned on in high school and continued into work as an industrial pipe fitter/welder where I certified on power piping and pressure vessels. Worked as a fitter for MIG (all shield gas) welders mostly in the fab shop environment. MIG was never used outside. I asked them about MIG welding and the learning curve. They all told me that the biggest problem with beginning was getting penetration. Vertical and overhead positions were avoided with a passion. For a lot of repair work you must be proficient in positions other than flat. Easy to lay a nice looking bead but hard to get in the root weld that gave full penetration. Once a solid first pass was in on schedule 40 they could then finish out with only one more pass but ti took lot of amps a slow to allow the build up. All the MIG welders were also SMAW welders.
What I see today is folks trying to MIG with small amp output and doing one pass. Looks good but weld is weak and will snap under any stress. You still have to follow all the same prep; bevels, clean, solid root pass that provides full penetration showing a small bead on the back side same as with SMAW. The little 90 amp units won't cut it on thicker than 1/8" with out more several passes to fill up the bevel. 1/2" material will take many passes where where SMAW is a three pass job with the right rod. If I was going to buy one it would be at least 150 A capable and be gas shield. I will probably stay with SMAW till I die.
Bottom line: in my humble opinion; MIG will not make a poor welder into a good welder without the same learning curve to be a decent SMAW welder. I burned 100# of 1/8" 6010 just preparing to being an acceptable welder in the trade. Many nights at the my Union's welding school shop.
Several of the implements I have purchased were all MIG welded and had welds that failed at stress points. !/4" stock not beveled and zero penetration. They all looked perfect hut had to grind them out bevel and re-weld. Mostly right angle fillet welds.
Ron
   / How to transition to MIG? #36
Ron, solid info from a seasoned pro! Yes, it is easy to lay down a good looking weak bead with MIG but I have found it is not hard to get decent penetration running it a little 'hot' at least for the jobs I need it to do. I don't build road worthy or life depending welded stuff though either but I think a MIG weld can be just as good as a stick or even better in the hands of a good welder.
   / How to transition to MIG? #37
Once you start down the MIG road it seems it never ends. One gas is not enough, you start wanting multiple bottles so you can spray or weld different metals. I think the Hobart 210MVP is a good start.
I took a stick welding class in about 1980. I used stick for years. I picked up a used Hobart 2510 welder a few years ago which is basically a Miller 250. I had a lot of trouble figuring out the settings on my MIG welder. Sometimes I would run a good bead and other times I missed. I finally took a MIG welding class at my local college. They put me through the mill and I am a better MIG welder now. I am still no pro but I can MIG weld 5/8" plate vertical and put it through a bend test.
MIG looks pretty if you use gas, which C25 is what you start with. The problem is you can not use it out in the open because of wind. Gas MIG needs to be used in a garage or shop. So I recommend taking a class if you really want to learn to MIG weld.
If you are going to weld any kind of heavy plate dual shield seems to be the way to go. I like it any way. But it takes a high end MIG welder. I would think you need a least a 250 amp MIG welder.
I guess the question is do you really need MIG if you have a stick welder. I don't know. I am retired and it was fun to take a MIG class. Pipe welding would be the next class if I get an urge. I had a hard time on pipe in some positions. Nothing bigger than about 10 inch.
   / How to transition to MIG? #38
Thanks,
Rob
MIG is great. It's easy to learn and for doing big jobs it's fast. Unlike stick you're not always stopping because you've used up your rod. I got my MIG because Costco was selling a baby Lincoln (100a) welder for a good price. But it was flux core only and I eventually tried a friends SP-125 with shielding gas. As I was building roll cages at the time and didn't like cleaning up the flux I stepped up to the 255. back then it wasn't a huge jump in price. I think most of the basics have been covered here of what you need to know. I personally think MIG is the easiest to pick up and weld when you haven't had a need in months or even over a year. There's no trying to strike an arc or moisture in the rods causing issues to worry about.
My only point about finding a machine that can do more than just MIG was simply to make you think if down the road this might be something you could want to do. TIG is harder and very slow. For most average welders it's not something they will need. As for a stand alone MIG I would look at how much it'll cost to add a spool gun if welding aluminum might be something you'll try in the future. Again if it's not something you think you will need then it's a non issue.
   / How to transition to MIG? #39
I eat, drink and bleed MIG. Many of my projects are dirty or painted, so the grinder is your friend. Have not stick welded anything for many, many years.
   / How to transition to MIG? #40
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
