How to transition to MIG?
   / How to transition to MIG? #51
MinnesotaDave pretty much NAILED it back in post#17 -
"Mig is a good process - I use it as much as stick and tig. Faster to learn too.
Hard wire 0.030" (gas shielded) will do about anything you want - even outside. If it's windy, lean a piece of plywood up against the item to block it.
I use 0.030" and 0.035" way more than 0.024". I just used 0.035" for body panels a few months ago and it worked fine.
I use 100% co2 for shielding because it's cheap. Standard mixed gas works great too.
There is almost no need to get more fancy that regular mig wire, and 71t-11 self shielded flux core (for when you really can't use shielding gas).
In my opinion, everything else is just for goofing off and seeing if you like it (like spray arc or gas shielded flux core or pulse mig, etc.).
There are a few things to know. Wire feed speed is your amperage - it controls penetration (depth of fusion).
Voltage controls bead profile. If a bead is tall and ropey, increase volts to widen and flatten puddle.
If arc is spattery and unstable, bead wide and flat, lower voltage until it runs right.
Stay on the leading edge of the puddle. If you don't actually see the arc cut into fresh metal, then assume it didn't.
If you're just an occasional welder who fixes things as needed, you'll likely really like mig. Get one in the 180-200 amp size and weld happy"
Especially the part I highlighted - if that, and watching several of Jody's vids on weldingtipsandtricks.com doesn't let you make things you can't break with concerted efforts, you should probably SELL your mig machine and HIRE any welding done FOR ya :rolleyes:
Going from stick to MIG DOES require re-thinking on where your HEAD is; in order to keep a short stickout with a MIG torch you can NOT have your head BEHIND the torch, nor do you want to "DRAG" the torch (with actual MIG, as opposed to flux core) - so you need to get your head off to the side where you can SEE (per Dave's comment) - that lets you SEE that the arc is at the FRONT of the puddle, instead of just piling MORE "bird poop" on top. NOT doing this is where the majority of "internet fact" about no penetration comes from.
Bought my first stick machine around 1973, after the ex-pipeliner friend who taught me decided he wanted his SA-200 machine back (guess he thought a YEAR was a long enough loan) :laughing: - I immediately went looking for a replacement, ended up buying a 250 amp AC/DC machine (Solar, aka Lincoln/Century, etc) - then bought a transformer MM211 about 10 years ago, sold that to a friend a couple years later when I found a MM252 and 30A spool gun and 3 tanks for less than the bare welder costs. A few years later I ADDED the newer inverter MM211.
MIG is about 98% of what I use now, I've welded up to 3/4" steel (deep bevels, 2 passes) with the MM252 and subjected the result to 20 TONS of pressure with no failures. Somehow I doubt those welds lacked penetration... Steve
   / How to transition to MIG? #52
I wouldn't go telling people to weld trailer hitches with a 110v welder. I think it will end badly.
   / How to transition to MIG? #53
Don't weld a hitch for highway use with a 110v welder!!! How's that.
This hitch on the tractor front bucket is for running backward out to say a family tree I want to harvest but I already have an implement on the back that I don't want to dismount. Or more often, to maneuver that trailer in/out of the tight barn stall where it is stored.
This mount never has the stresses that would occur in highway use. It's a lightweight mount, originally half of a hitch assembly that clamped to an old fashioned spring-steel bumper long ago when the speed limit was 45mph. I wouldn't use that assembly today on the highway, either.
Agree, I wouldn't use the 110v welder for anything with highway stresses, or safety aspects. The photo was to illustrate that 110v welding is for light-duty applications.
   / How to transition to MIG? #55
Steve, how would you compare your old 211 transformer to your 211 inverter model? Just curious...
   / How to transition to MIG? #56
my lincoln 210 mp should be here tomorrow or monday gotta go get me some gas for it next i can let you know what i think of it if you like when i get it going
   / How to transition to MIG? #57
Definitely.
   / How to transition to MIG? #58
"Steve, how would you compare your old 211 transformer to your 211 inverter model?"
Similarities - both use max 8" spools come with only 10' gun, run on either 120 or 240 volts, and can use either manual or autoset. Neither will tell you what the numbers mean, altho there's kind of a "workaround" to figure out what the wire SPEED is doing - voltage too, but requires a helper and some note taking :rolleyes:
There was about a 3 year gap between using the older one and the newer (inverter) one, so I may be remembering wrong; it sorta seems like the transformer one was a little bit "smoother" - if so, it would likely be the transformer unit having slightly different inductance, just a "SWAG" on my part.
Differences - the inverter mm211 weighs 32 pounds less, has a beefier feed that is rated for a 15' gun (transformer one is NOT recommended for more than a 10' gun) - Autoset on the transformer one expects C25 gas, set for either .030 or .035 wire, mild steel ONLY, flux core in MANUAL ONLY,aluminum in MANUAL ONLY, with spoolgun. Spoolmate 100 or Spoolmate 150. Spoolmate 150 uses different consumables IIRC, has a 20' reach. the 100 is only a 12' reach.
Inverter model offers Autoset choices of THREE wire sizes, .024 to .035 - Separate Autoset choices of flux core, MIG stainless, MIG steel/C25, MIG steel/C100 or MIG aluminum (spool gun) - I've not done stainless yet, according to the manual the autoset expects Tri-mix gas.
Transformer version the fan runs constant, inverter version fan on demand.
Basically, Miller addressed every complaint I had about the transformer version that was economically feasible; I just can't figure out what they were smoking when they used the EXACT same model name :confused:
As I mentioned in another thread, if I still had the transformer model I would NOT have been able to build the "offroad" cart I did for the inverter model
https://www.tractorbynet.com/forums/build-yourself/387658-container-weld-shop-build-20.html
Because that extra 32 pounds would've made the cart too top heavy for the "hand truck mode" to be practical. The cart was a lot of work to get just the way I wanted it, but it's been well worth the effort. It makes the smaller mig a LOT more portable than the dual running gear MM252, makes my 4 different work areas less of a PITA.
Even so, they're gonna have a hard time prying EITHER machine from my "cold dead fingers" :laughing: ... Steve
   / How to transition to MIG? #59
More good info. Thanks. Most of my welding will be done inside. I'd be doing mostly fab work and not that much repair and I am fortunate to have a huge shed anyway that can accommodate anything I'd be working on.
There was a comment about looking into a multi-process machine. That would be great to have something like a Miller Multimatic 215, but at close to $1850 for one (with TIG kit) that's a whole different investment than an $800 210MVP. If I could get into one for a few hundred more than the 210 I might consider it. Is there anything else out there that fits that bill?
ETA: I see there is a Klutch MP200siDV MIG/TIG/stick/spoolgun welder out there at NorthernTool for $860 (TIG torch is another $99). Is that a decent multi-process unit or is this a Harbor Freight level item?
Regarding the duty cycle comment above... A Hobart Handler 210MVP, which is pretty highly regarded as a great MIG welder (for non-production use) has a 30% duty cycle (230 V: 150 A at 23 VDC, 30% duty cycle). 30% duty cycle at that amperage must be pretty decent when you get right down to actual use or this model wouldn't be so well thought of. It's certainly not a "entry level, cheapo" unit. I totally get that if you're a fab shop welding product all day you're not using one of these but for hobby/home/garage use it must be pretty capable & suitable.
Rob[/
I considered an MP for a very long time before deciding that they were way more machine than I would ever be able to utilize-I finally settled on a 220v stick/MIG (Viper)
I did find a used 110 MIG/flux core that I keep around set up for flux core-it’s my ‘take to the outside’ quick fix welder.
   / How to transition to MIG? #60
i like the 211si for the price and wty, i came close to pulling the trigger on it outside of the 210mp but i could not get the guy with the one for sale to provide a receipt for purchase because it was a gift so my wty would not have been valid per everlast.
same for lincoln, i found a slightly used one and it would not have been honored either due to not being original owner
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2009 Jeep Grand Cherokee 4WD SUV (A59231)
2009 Jeep Grand...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
