Knowing what you know now, which mower would you buy?
   / Knowing what you know now, which mower would you buy? #21
I haven’t seen a flail on a zero turn. The F is available in four wheel drive and is markedly better on slopes.
It’s also markedly more tippy. When I demoed it on a hillside, it felt more topheavy than the ZD.
   / Knowing what you know now, which mower would you buy? #22
Mow it twice!
   / Knowing what you know now, which mower would you buy? #25
I have owned Kubota diesel zero turn and ferris zero turn mowers.If you have bumpy ground go with the ferris as it has the independent suspension.The Kubota beat the h-ll out of me.
   / Knowing what you know now, which mower would you buy? #26
You know you are soooo right. I saw a Ferris at a customers place and asked if I could run it. The suspension was amazing, and it was really fast.
The ZD331 I have pretty much needs some seat work. It isn’t the best ride in the world....
   / Knowing what you know now, which mower would you buy? #27
The ZD331 I have pretty much needs some seat work. It isn稚 the best ride in the world....
Loved the Kubota diesel it even had suspension seat but the ride was still rough.I had back surgery about 15 years ago I sure that did not help matters.
   / Knowing what you know now, which mower would you buy? #28
Theres this guy in my neighborhood that did a simple modification to his hard riding zero turn that I MUST do.
He removed the seat and added simple hard rubber bushings, like thick washers between seat mounting bolts and frame and he said it made a world of difference. Costs next to nothing.
I have to do this before mowing season gets started.
   / Knowing what you know now, which mower would you buy? #29
How often do you mow, and how long does it take you? A good commercial zero turn will mow 5 acres or more in an hour. Mow once a week and you won't let the grass get to 8". I used to mow a field once a season with a bush hog. Grass would be 2-3 feet tall and it would take me all day. Then I started mowing once every 5-6 weeks, and it would go faster, but still take too long. Around that time I bought a Hustler residential zero turn for my lawn, and used it on the field, took 90 minutes. A few year later I upgraded to a Hustler commercial mower and can mow it in 50 minutes. My mower will do 6 acres an hour if you can run full speed. Helps to have both flex forks on the mower and an air ride seat. I mow it every week. I like having a well cut field past my backyard, and I enjoy my time on the mower.
   / Knowing what you know now, which mower would you buy? #30
BuggyMasters You should really look at Grasshopper mowers and especially the Front Mount mowers. If there is a Grasshopper Dealer close by try to demo one of these before you buy any other mower.
I DO NOT YET own a Grasshopper. But I have some property similar to the picture you posted. I have been looking at the Grasshopper and with the front mount the maintenance is much easier and they have some pretty powerful models available. I will probably get a Grasshopper in the next year or so.
Model Chooser | Grasshopper Mower
TBS
2010 BIG TEX 18 TANDEM AXLE TRASH TRAILER (A53843)
2010 BIG TEX 18...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2018 Ford F-550 4x4 Cab and Chassis Truck (A51692)
2018 Ford F-550...
2014 FORD F-350 (A53422)
2014 FORD F-350...
