aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 16,985
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
I am confused, if you disconnect the implement from the quick connect that will stop all flow through the quick connect.Many thanks, Aczian, Ericm979, and Bukitcase for your posts and links,
I really appreciate your taking the time to respond to what I am trying to do. I thought I included all the information, but I left a few things out.
First of all, I want to keep all the plumbing I have installed as is . . . secondly, I don't feel I have the ability to do any changes to the plumbing myself, which is why I was hoping to find JUST a plug in type On-Off valve with a lever or knob control. So ideally what I was looking for was a manual valve that would just plug into the existing front and rear dual couplings to control oil flow to each end. And these manual, plug in valves could removed at any time if I wanted to connect either front or rear implement to the actual dual couplings as is normally done.
Many thanks for your replies and suggestions . . . very much appreciated.
FredSG
I thought you wanted to be able to (for example) leave the grapple connected while using your hydraulic top link.
You could certainly use high pressure ball valves as was suggested earlier on the hydraulic line going to the grapple, you could disconnect the male quick connect on the grapple and put a high pressure ball valve in there then reinstall the male quick connect.
Then you could do the same thing on your hydraulic top link with a ball valve between the hose going to the top link and the male quick disconnect.
That would let you turn off either one but keep the plumbing on the tractor unchanged.
A valve such as this one would probably work for that: 3/8" NPT Carbon Steel 725 PSI Ball Valve | Ball Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
Aaron Z
