Cylinder repair suggestions?
   / Cylinder repair suggestions? #11
Is the back side original? I would turn the shaft 180 degrees and drill a zerk hole on that side and put the weld to the back.
This ^^^. There are no awards given for pretty welds. The reward for a successful weld is a useful part.
   / Cylinder repair suggestions? #12
I was primarily thinking that it would be easier to drill and tap there, less chance of hitting a hardened weld pocket and breaking a bit or tap, which would be a big problem in its own right.
I totally agree with this sentiment RickB, on the whole. I do have a detail part of my brain that does like to have things looking tidy and clean lines etal too. Case in point. Earlier this week I finished grinding off the "Tack welds" on the Tommygate I have for replacing the pins (10 of them). I used the Lil MIG and it was not pretty. I will be gently grinding several spots down to remove the splatter balls and yeuckiness that the wire-wheel didn't solve. Yeah I'm a really rusty inexperienced welder.....
I will quickly admit that i a$$umed that the idea of flipping it was for a much more flat/uniform surface for the drill/tap & installing a replacement zerk..... IF the inspection shows it can happen. (fingers crossed)
   / Cylinder repair suggestions? #15
I would cut off the old rod end and make a new one out of scrap steel, bore it .010”-.012” over the pin size, weld it and go digging.
   / Cylinder repair suggestions? #16
More than likely this is what happened.....and they smashed it back together and welded it.
   / Cylinder repair suggestions? #17
So I guess you bought the Bolens G272 tractor with the Kelly backhoe in Waco. I was talking to him when it first came out. He had a mower deck which I think he sold off first. He lowered the price for me a lot but it seemed like a real project to fix. None of the glow plug system works on the tractor. I was having a hard on where to find parts. I think it is a nice sized system.
Actually, no I didn't. That AD in Waco was not visible when I found this Kelley BH in Tyler area, from a used equipment sales/auction place. Saw it via a Google search that it was cross posted in two different auction sites: their own and another. I got it back at the end of January. I even made a post asking about inline filter suggestions for it then too. In the last 2 weeks I saw 2 Kelley's on Craigslist for sale by them selves & 1 on a Cub cadet in Upstate NY.
I see a parallel to the situation but, alas I'm not aware of how bad this one cracked apart. I can say that from my current awareness that it doesn't appear to be out of round on the pin. I have pressure washed it a couple times and then the time I spent redoing the PTO hoses, putting an inline filter on it and some QD's on the Pump to make the removal of the PTO MUCH easier for me.
https://www.tractorbynet.com/forums/hydraulics/421557-pto-pump-filter-recommendations-pseudo.html
I posted pics of it on a different BH thread here on post #66 I think? In early February....
https://www.tractorbynet.com/forums...-how-often-do-you-actually-7.html#post5646999
Update from their website: Kelley Manufacturing : Tractor Backhoes & Parts Manufacturer Ohio
And just a few moments ago, a call to CSR... Worst case pricing is -> The piston/Rod itself is ~$80+ & the seal kit is ~$36 so if I have to order replacement it'll be about $150+ with shipping included via UPS.
1) Rod Assembly Part Number: SCY10006
2) 2” x 1 3/8” Rod Polypack Seal Kit Part Number: 99-001-093
On the best case pricing -> The piston is supposed to be spin-able to have access to other side for drill/tap for a zerk.
So All I'd be looking at is a Zerk fitting?
As I have drill bits and Tap kit that "should be small enough."
2018 MACK CHU613 DAYCAB (A55745)
2018 MACK CHU613...
2011 FREIGHTLINER CORONADO (A55745)
2011 FREIGHTLINER...
JCB 409T4 WHEEL LOADER (A52707)
JCB 409T4 WHEEL...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2006 VOLVO VNL (A55745)
2006 VOLVO VNL...
