Looking for a heavy duty 4' box blade
   / Looking for a heavy duty 4' box blade #1
Tifford
Jordan
Mahindra 25 hst
Apologize if this is in the wrong forum.
I have a mahindra 25hp emax hst that weighs around 1500 pounds....1700 with me on it. I've pretty much settled on getting a 4' box blade. It's going to help me maintain 1/2 mile of dirt/gravel road. Smoothing out pot holes probably being the main job.
Looking for recommendations for a heavy duty box blade that will last at least for a few years. I have a mahindra dealer nearby as well as tractor supply and a massy furgusion dealer close.
Who makes a cat 1 4' box blade that will last?
   / Looking for a heavy duty 4' box blade #2
I run a 6ft box blade behind my mahindra 2810. It is 28 hp but it is a lot heavier than your max. i think any standard duty box blade will suit your needs.I had a 5 ft mahindra box blade and it worked fine, i just wanted a wider one to make ditch work easier. I live at the end of a mile long gravel road.
Thanks for the quick reply.
I was hoping the standard duty mahindra box blade would stand up to the abuse. I like the dealer I go through. They've only messed up one time and they humbly apologized for the one time mess up. Great guys to deal with.
   / Looking for a heavy duty 4' box blade #4
If your main job for it is road maintenance, a grading scraper may be better.
Bruce
   / Looking for a heavy duty 4' box blade #5
If you were mowing with this tractor would you use a 4ft mower deck?
I use a 5ft with my JD2210. Wouldn't want it any narrower.
I mow with a 6' Italian made rear mower. But I'm not sure what mowing has to do with dirt/gravel road maintenance.
   / Looking for a heavy duty 4' box blade #7
I was vague.
My point is why would you buy a BB that is possibly narrower than your tractor? It sucks if you can't cover your tracks.
You outweigh me by a couple hundred pounds so you can surely handle a 5ft BB.
Bruce
The box blade is around $700. There is a grader that my dealer sells but it is around $1,400.
House is paid for and just paid off my truck so I could afford it but I'd rather (for now) try the cheaper of the two options.
I was vague.
I can cover my tracks. 47 is the tractor width. 4 feet is 48"
   / Looking for a heavy duty 4' box blade #10
Excellent example. So if you want to blade next to an object you have to get your tire sidewall within 1/2" of the object?
   / Looking for a heavy duty 4' box blade #11
I also have a JD2210 and pull the heavy duty Frontier 60” BoxBlade. Works great and I maintain 4 miles of gravel road with it. I bought it new from JD dealer for about $800. I agree wider is better for getting passed mail boxes.
   / Looking for a heavy duty 4' box blade #12
Most 3pt hitches have some sideways play/adjustment. You can set the implement off to one side by at least a few inches.
The smaller blade will be easier to pull when it's loaded up with dirt. If you're not moving dirt like that, only grading a little off the top, you could use a wider blade.
Gearmore make some sturdy box blades, but they're sold mostly in the western US. I've been happy with both of the ones I've had.
   / Looking for a heavy duty 4' box blade #13
You stop and adjust your sway links all the time to blade next to objects?
   / Looking for a heavy duty 4' box blade #14
I bought a JD 4 foot box blade last year and it seems heavy duty.
   / Looking for a heavy duty 4' box blade #15
I have the county line 4 footer from TSC, very tough-well built. I have a 24 HP and will always lose traction before I lose the HP to pull it...I actually have yet to lose the HP to pull it.
Have done 18-18 yard truck loads of 2.1 gravel with it. My only complaint is once again-traction but I have turf tires.
   / Looking for a heavy duty 4' box blade #16
I built a suitcase weight rack for the front of my JD2210. When using the BB I throw a couple weights on. If I begin spinning I pick up just a tad on the BB and no more spinning.
   / Looking for a heavy duty 4' box blade #17
Usually I'll be needing to get close on only one side and I know ahead of time which it is. So I bias the implement to that side when I put it on. But with sliding stabilizers and a tilt cylinder it does not take long to bias it to the other side and readjust the angle. Without those it will take longer. I sure do not miss the turnbuckles!
RING 2 STARTS HERE @ 9:15 AM (A60430)
RING 2 STARTS HERE...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
5th Wheel Hitch (A59230)
5th Wheel Hitch...
