Fixing and caulking rotting joints on exterior wood stairs
   / Fixing and caulking rotting joints on exterior wood stairs #41
New stair section looks nice but I notice the wood is still touching on the ends of the treads. Looks more stable but didn't someone suggest leaving a 1/4" gap at the ends to prevent water collection and rot?
I read through this for education and don't know squat about building with wood.
Looks good lots of room for air circulation to keep stringers dry .:thumbsup::drink:
Compared to the old stairs, this looks like a ladder! But I really hope it will help with circulation and moisture.
I didn't see a way to leave a gap with these brackets due to the narrow width and position of screw holes. If they made wider brackets it would have been a great idea. I did, however, soak the piss out of the cut ends of the treads with copper coat treatment. So that ought to help immensely.
   / Fixing and caulking rotting joints on exterior wood stairs #44
They look nice. Did you bolt the brackets in place for the treads? I don't think I would trust anything else over time.
Can you drive a pipe into the ground like you would a T post and use that for bracing of your railing posts?
   / Fixing and caulking rotting joints on exterior wood stairs #45
Where the steps meet the risers (sides) I'd like to use a durable caulking like Flextra (polyurethane) in order to keep water from entering the ends.
Each bracket has four 1/4" Simpson lags into the stringer. I debated lags versus through-bolting quite a bit and it was a tossup in my mind. We'll see how it turns out...
I could drive pipes into the ground, in fact those could probably be the posts themselves if they were long enough. I have seen someone do a railing system with fence pipe and there are fittings for that too.
I was planning to wait a few months for the treated wood to dry out and shrink, and then see what the joints look like.
   / Fixing and caulking rotting joints on exterior wood stairs #48
As far as I no there is no structural PVC .and conduit would never pass any inspection.:drink:
   / Fixing and caulking rotting joints on exterior wood stairs #49
What about filling the conduit with concrete and rebar? That way it'd be a concrete post with a "decorative" PVC coating. I've seen concrete fence posts and railroad ties, so i'd think using the PVC for a form and leaving it in place should (?) be acceptable.
   / Fixing and caulking rotting joints on exterior wood stairs #50
While a good plan, it is never a bad idea to prevent even the earliest water penetration from being trapped in there.
I suggested Flextra as it is a polyurethane based caulking and it is extremely flexible and will stretch many times its base size.
Basically the same as windshield adhesive.
2024 JOHN DEERE 4044M LOT NUMBER 65 (A53084)
2024 JOHN DEERE...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
2020 Kubota SVL 75-2 Skid Steer (A51573)
2020 Kubota SVL...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2013 CHEVROLET SILVERADO 1500 (A52472)
2013 CHEVROLET...
