Technique to weld DOM tube to flat plate
   / Technique to weld DOM tube to flat plate #11
Yeah, I thought of that later too. Must not be too much load.
Just weld it on, being careful to keep it aligned in the proper position.
No comment on the OVRWLD?
   / Technique to weld DOM tube to flat plate #12
Trying to not encourage you today my friend. Think what we'll be like if the "lockdown" grows...... :D
   / Technique to weld DOM tube to flat plate #16
Stitch weld it and make sure the wire penetrates as deep in the recess as possible.
   / Technique to weld DOM tube to flat plate #17
   / Technique to weld DOM tube to flat plate #18
Shop Lockdown
No WiFi in my shop but apparently no limits on my phone data these days so....I guess I’m good. Adjustments.jpg
   / Technique to weld DOM tube to flat plate #19
Shop Lockdown
No WiFi in my shop but apparently no limits on my phone data theses days so....I guess I’m good.
I hear ya!!!! XM in mine.
You don't even have dirt in your floor cracks....... :cool:
I decided to just grind the flat spot a little wider/deeper. That helped make the V not as deep. It worked well. Thanks for the tips.
It is not really a structural part. I'm adding tubes on my stowable trailer ramps as a hinge to run a rod through. This will allow me to turn them into flip-up ramps. And I can still pull the rod out and stow them as before. I guess sort of structural but not with any real load on it.
Thanks,
Rob
P.S. The light spatter on the tube is from my weld. The heavy spatter elsewhere is from the trailer manufacturer. They did pretty well on the trailer itself but maybe they had an intern welding up the ramps?
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2020 Kubota B2401 (A50120)
2020 Kubota B2401...
2018 Kubota KX033-4 Midi Excavator (RIDE AND DRIVE) (A50774)
2018 Kubota...
2017 Claas Jaguar 860 Forage Harvester (A52748)
2017 Claas Jaguar...
2024 New Holland T8.410 MFWD Tractor (A52748)
2024 New Holland...
