Front 2nd axle gear=have you seen worse?
   / Front 2nd axle gear=have you seen worse? #61
Note that neither tractors nor cars/trucks use this kind of gear in their differentials. At least as far as I have seen. If anyone has pix of a differential ring or pinion gear made like the OP's hub gear, please post it. Whether it is my Kubota or my Toyota pickup, you are going to find machined ring/pinion in the diffs, and careful attention to tooth contact patch will be necessary in any repair.
   / Front 2nd axle gear=have you seen worse? #62
That's what we're trying to say for a couple posts now.
Those sintered gears are only used on the final drives of the front axles on tractors that don't use planetary drives.
   / Front 2nd axle gear=have you seen worse? #63
No, but I drilled them on my drill press, worked out OK and I still had real safety wire from my aviation days.
And have the safety wire pull/twist tool so they also look real pretty, LOL.
Also will add that I still had my Millbar safety wire pliers to do the job.
They make nice neat twists every time.
Actually at one time I had about 150 pairs of those Millbar's from a surplus source.
I paid $1.00 each at the time and sold them easily to my aviation buddies.
Also did great mail order sales via a trade magazine called 'Trade-A Plane'.
Good old days!
I note that those pliers are like gold at the current price. ($140.00)
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2018 Ford Fusion Sedan (A55853)
2018 Ford Fusion...
Freighliner Tender Truck (A55302)
Freighliner Tender...
2012 PETERBILT 388 DAYCAB (A55745)
2012 PETERBILT 388...
