What dumb thing did you do today?
   / What dumb thing did you do today? #41
Yep, I am surprised they didn't rip.
As a little side note, If the tractor had been a Kubota the style of quick connect on the tractor, if you pull on the hoses they will automatically disconnect.
you sure...?
   / What dumb thing did you do today? #42
I have fun with my channel on YouTube. And I have no shame so admitting mistakes is amusing to me.
I really respect you for that. Good for you. :thumbsup::thumbsup::thumbsup:
   / What dumb thing did you do today? #43
you sure...?
Take a look at some of the female AG connectors on some some of the larger Kubota's and you will notice there is no outer ring for you to get your hand on. They move in the housing that surrounds them as you pull on the hose the "guts" of the connector move with the hose and the outer shell stays fixed in the housing and the hose disconnects. And when you shove the male connector into the female it moves backward and also releases the balls and the connection is accomplished without your hand on the outer shell. *
*yeah, yeah, I said male, female, balls, and hand all in the same sentence. But we are not in the 8th grade anymore.
   / What dumb thing did you do today? #44
You forgot, Pull on the hose... :cool2:
   / What dumb thing did you do today? #46
You have to admit that the use of the double acting outer shell and mounting that to a housing is a really cool idea to prevent damage to hoses if the operator forgets to disconnect the hoses and just drives the tractor away. We know it can and does happen. We have visual proof! :)
   / What dumb thing did you do today? #48
   / What dumb thing did you do today? #49
I see now, The ones I have you have to slide back the sleeve to release......
Right, same as my Kioti, but the double acting ones are kinda cool.
   / What dumb thing did you do today? #50
That top link has a locking valve so it will not move without hydro pressure. That’s the reason I fired up the tractor.
...but can’t you still “retract” the cylinder with the tractor off if the snowblower is pushing on the cylinder? Sort of like lowering the 3pth or FEL with the tractor off?
It will retract until there’s no force and that’s when the pin will be unbound.
I realize we’re discussing minutiae here...
2012 Peterbilt 337 IMT 6025 14,000lb 5 Ton Crane Mechanics Truck (A55788)
2012 Peterbilt 337...
CATERPILLAR HANG ON 71" WHEEL LOADER FORKS (A51406)
CATERPILLAR HANG...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
COUNTERWEIGHT FOR CATERPILLAR 330C (A54756)
COUNTERWEIGHT FOR...
2000 Ford F-550 Altec AT35-G 35ft Bucket Truck (A53422)
2000 Ford F-550...
UNUSED FUTURE FT13CJ EXCAVATOR (A54756)
UNUSED FUTURE...
