JD Hydraulic Cylinder Rebuild Help?
   / JD Hydraulic Cylinder Rebuild Help? #31
420 SN appears to be 004692. lift & bucket cylinder kit appear to require the same kit AH176344
Thanks just ordered 2 kits. Do you happen to have a website on a how to ?
   / JD Hydraulic Cylinder Rebuild Help? #33
Do you mean rods?
pistons are what goes into the hydraulic cylinders and gets pushed out and in by the hydraulic pressure, some people call them rods, but their function is as a piston..
   / JD Hydraulic Cylinder Rebuild Help? #34
Found my issue. One of the lift cylinders was leaking internally. Seals were cracked and pinched. Fixed my issue right away
   / JD Hydraulic Cylinder Rebuild Help? #35
Here is what I learned when I did mine and had the same problem:
In the seal kit there is a orange plastic piece...in the end of the cylinder there is a groove...Now put the plastic piece in the groove, make sure its flush all the around. Now you can do as Andy said...give it a good YANK!
What is happening is part #6 is expanding and catching in the groove stopping you from pulling out the rod. Drove me crazy also!
When you go to put the new seals on the piston, boil them in water for a while to soften them up. I then wrapped a piece of thin aluminum flashing around the piston and clamped it with a hose clamp while they cooled-but this was probably unnecessary.
Let me know if this helps...
Hi Kenny,
Not sure if you are still receiving after all these years but a big THANK YOU for sharing this. One of the bucket cylinders on my 200CX had started to weep so, being big on preventive maintenance I ordered a replacement seal kit, Without your guidance (and chains; lifting slings, an immoveable object and a 4 Wheel drive) I would not have been able to extract the piston.
Then...wait for it.... the kit is correct according to the JD parts manual but my cylinder is a previous model :eek:
Had rebuild the cylinder with the old parts because who knows how long it will take for JD Australia to work out the problem with JD USA. Trap for new players!:confused2: getting the internal stop ring on the end plug back into the cylinder AND MAKING SURE that it is properly seated took three attempts. That's a lot of oil to clean up off the workshop floor.
Cheers from South Australia :drink:
   / JD Hydraulic Cylinder Rebuild Help? #36
Hi Kenny,
I'm still here! Much to some's dismay :laughing:
Glad the info was helpful, that's whats great about these forums vs FakeBook, everything is basically indexed and searchable so it helps people YEARS later too.
2019 International DuraStar 4300 24FT Box Truck (A53422)
2019 International...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2018 FREIGHTLINER...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
2022 CATERPILLAR 315GC EXCAVATOR (A52707)
2022 CATERPILLAR...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A54815)
2022 McConnel...
