Ordered Ammo for a gun I don't own
   / Ordered Ammo for a gun I don't own #71
Good point! I have the same rifle...with the threaded barrel and is very quiet suppressed with subsonic ammo (Gemtech makes great subsonic .22LR)
That was/is my plan as well ...just haven't gotten around to getting a silencer/suppressor yet (be nice if they went ahead and remove the NFA paperwork requirements).
Though even without that, having both is really handy on those rare occasions that I find some ammo that doesn't want to feed through the 10-22. I actually need to replace some parts on the 10-22 because I've put enough rounds through it that some of the springs have gotten weak. :laughing:
...and if you can find one of the 10-22's that uses the same interchangeable stock system as the Ruger American Rimfire rifles.... :thumbsup: (parts compatibility & interchangeability can be such a nice thing)
   / Ordered Ammo for a gun I don't own #72
While you're replacing parts, might want to replace the stock buffer pin in the receiver. The stock is steel and, as you know, the receiver housing is aluminum. I wouldn't be surprised if you've already done this, BTW.
One reason I chose the Savage over the Ruger is the receiver is steel. So far I am happy with my choice. I fired a full mag through it and it performed as it should. So far my only complaint was the sharp edges on the magazines and it took all of 2 minutes to file them all smooth and black the shiny with a sharpie.
I may yet order a speed loader but the holder I made from a chunk of wood and a small screwdriver makes loading much smoother and doesn't take that long.
The 380 Hornaday ammo I bought through Academy doesn't show an option to reorder so I might have got the last of what they had. It does show available from other sources. Not sure I can afford to target practice with it at 80+ cents per round. The problem is it does seem to shoot more accurately than the Winchester ammo I bought. That is probably just my inexperience with the weapon and ammo choices though.
Time and practice will tell.
   / Ordered Ammo for a gun I don't own #75
Yeah, steel is definitely nice, but the 10/22 has been manufactured since 1964...and can't say I've ever read about receiver failures.
I did a couple mods to my 10/22 takedown. The buffer pin was one...I also added a bolt hold back kit. I reckon I should do the same to the 10/22 compact as well...just don't shoot that one as much.
   / Ordered Ammo for a gun I don't own #76
yes I have :D --- in fact that was one of the first things I had to replace as it broke in use - no wear on the receiver though. I believe I replaced it with a hard nylon one (it's been a couple years), and shortly after I saw a method of using a steel dowel inserted in tubing. Definitely enjoy the broad aftermarket support for the 10/22 - even though I mostly use Ruger parts.
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53473)
2014 Doyle Dry...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A54313)
2012 INTERNATIONAL...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
2017 INTERNATIONAL DURASTAR 4400 (A53843)
2017 INTERNATIONAL...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
