L Series HST Recall
   / L Series HST Recall #11
PSB-2020-046, released on 04/13/20 shows the models and serial number ranges. A revised list for L4701 was released on 04/27/2020 on the Dealer Portal.
L3560HST......45615-45973, 46090
L4060HST......45065-45446, 45826
L47...............50103-50106, 52251-52334
L4760HST......42560-42673
L5460HST......41666-41740
L6060HST......47691-48092
M62..............50065, 50066, 51350-51434
MX4800HST...54697-54979, 54981, 54986, 54990-54992, 54995, 54999-55011
MX5200HST...67080-68017
MX5800HST...55887-56223
L4701HST......65720-69754 (List has been revised as some unit in this range are not affected. L4701HST owners need to supply HST serial number to confirm their unit is affected)
Kubota is also forgoing Dealer Certification for use of UPTIME in this instance. All levels of dealers will be able to get the customer's rental assistance for this repair.
approx. 6,000 units affected, what a mess
   / L Series HST Recall #12
My L6060 which was delivered a couple of weeks ago escaped it, which was great news. I wasn’t looking forward to having my brand new tractor split by the dealer, and being without it for the busy spring season.
Thank you for providing the details, I called Kubota before seeing that you had listed the serial numbers affected, and they concurred that there no open issues on my machine.
   / L Series HST Recall #13
Yep, got our letter yesterday. Called selling dealer, they had no idea or proposed fix. Completely shocked by this, not something I expected from a 2 month old machine.
   / L Series HST Recall #14
Thank you for submitting the list.
It looks like they must have found some locktite to use on my L47. My ser number falls in-between the two runs @ 521xx.
Odd that there is a break in the numbers like that.
   / L Series HST Recall #15
No MX6000's. Odd that a run on the 5800's is present.
   / L Series HST Recall #16
Thanks for sharing the list. Looks like I lucked out
   / L Series HST Recall #17
My 2016 L4060 has a serial number starting with 42, well before that serial number range.
Thanks for posting the info.
   / L Series HST Recall #18
****, I just went out to my L6060 and my serial number is recalled. What a massive disappointment. All for a potential loose bolt? If it does take 40 hours for a skilled tech to repair this issue, would it better to just not do anything until there is an actual problem. I can't stomach the thought of dismantling the whole tractor and then reassembling. That will inevitably lead to many other problems as a result of them tearing the tractor in half and trying to piece it back together. My dealer had to swap out my hood when I bought it because there was a small dent on it. This resulted in 3 small issues because they never put the replacement hood on properly. I'm a big believer in "not breaking the factory seal." This violates that in the worst way.
I can't believe this got by the" Passed by Chief Inspector" fella who put that nice red sticker on my tractor.
DEUTZ MARATHON...
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
