Wheel spacers, GC series tractors.
   / Wheel spacers, GC series tractors. #21
Thanks for the update. I am still thinking 2" spacers for my work, but knowing the 3" seem to fit on yours is nice.
Just an fyi. I installed 3 inch spacers from brotek recently and can confirm they work on my setup with a 60 inch deck. It's tight but they do work. I mowed for an hour and kept a very close eye on the clearance for about an hour and never had an issue with rubbing. I'm using turf tires - not sure if they're narrower than others.
Good to know man, thanks!
   / Wheel spacers, GC series tractors. #23
After having 3 inch spacers on for a month or so, and navigating various hilly areas on property, I can safely say the 1715 seems a lot more stable in situations that earlier caused "butt pucker"....
Dale
   / Wheel spacers, GC series tractors. #24
Dale
100% agree
   / Wheel spacers, GC series tractors. #25
So, is a set of 3" spacers 3" on each side, or a total of 3", 1.5" on each side? My property has a lot of surfaces that are far from level. I wouldn't min some more stability and I don't plan of running a MMM.
3" per side, Steve.
   / Wheel spacers, GC series tractors. #28
Can any of you tell me if the bolt pattern is 5x5.5? I found a set locally for $20, but I can't remember if that is the right lug pattern.
   / Wheel spacers, GC series tractors. #29
5x4.5 5 lug are the ones I used for my GC1720
   / Wheel spacers, GC series tractors. #30
I am only going rear only at this time.... Waiting to see how much increased stability is... May consider fronts later...
Dale
Several posts on this elsewhere -- spacers in front have no effect because the front axle pivots in the middle. I do not think there are any negatives to using rear spacers BUT I am not a backhoe user (which exerts different forces) and someone mentioned the rear axle housing may be cast aluminium... If I were a backhoe user I'd wonder about warrantees , etc.
2020 JOHN DEERE 333G SKID STEER (A52707)
2020 JOHN DEERE...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
(INOP) 2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A54756)
(INOP) 2016...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A57193)
UNUSED FUTURE MINI...
John Deere 2520 (A53317)
John Deere 2520...
