Linkage shaft for shifting into 4wd broke on John Deere 110 TLB
   / Linkage shaft for shifting into 4wd broke on John Deere 110 TLB
I double checked the hydraulic fluid level and tried adjusting the knob that controls how fast the rockshaft drops. I also checked the "backhoe presence" switch and it has continuity when not depressed and there is no continuity when it is depressed.
Figured out the problem. The connector for the back up alarm was connected to the connector that should have been connected to the backhoe diverter solenoid.
   / Linkage shaft for shifting into 4wd broke on John Deere 110 TLB #13
Thanks for updating. JD should have used two different connectors to fool proof it.
I'm thinking it is just a coincidence that both connecters fit, they have only 2" of wire coming out from the main harness and that they are right next to each other but if the engineers did that on purpose they got me!!!
I'm just super happy I was able to split the tractor and get it back together. That was the biggest/most involved vehicle repair that I have done.
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
BEFCO DISC MOWER (A52708)
BEFCO DISC MOWER...
S/A Utility Trailer (A56858)
S/A Utility...
