Linkage shaft for shifting into 4wd broke on John Deere 110 TLB
   / Linkage shaft for shifting into 4wd broke on John Deere 110 TLB
I double checked the hydraulic fluid level and tried adjusting the knob that controls how fast the rockshaft drops. I also checked the "backhoe presence" switch and it has continuity when not depressed and there is no continuity when it is depressed.
Figured out the problem. The connector for the back up alarm was connected to the connector that should have been connected to the backhoe diverter solenoid.
   / Linkage shaft for shifting into 4wd broke on John Deere 110 TLB #13
Thanks for updating. JD should have used two different connectors to fool proof it.
I'm thinking it is just a coincidence that both connecters fit, they have only 2" of wire coming out from the main harness and that they are right next to each other but if the engineers did that on purpose they got me!!!
I'm just super happy I was able to split the tractor and get it back together. That was the biggest/most involved vehicle repair that I have done.
2025 IRANCH IRTS2 Tie-Down Ratchet Straps (A55974)
2025 IRANCH IRTS2...
23" X 27" ROLLING METAL CART (A58374)
23" X 27" ROLLING...
1995 Advance Mixer CM3A6811 11 Yard Tri-Axle Concrete Mixer Truck (A56858)
1995 Advance Mixer...
JOHN DEERE 6115D MFWD TRACTOR (A52708)
JOHN DEERE 6115D...
2013 John Deere 650K Crawler Tractor Dozer (A56857)
2013 John Deere...
BOY ON JOHN DEERE TRACTOR PULLING JOHN DEERE WAGON (A58374)
BOY ON JOHN DEERE...
