GC17xx, coolant change
   / GC17xx, coolant change #21
Addict, My MF manual says to use Massey Ferguson coolant but no specs are given. Also, the manual says change at 1000 hours. I change it a bit more often that that. I think that a quality 50/50 anti freeze is sufficient. Also, I change engine oil every year as well as the oil filter. I use Mobil Delvac 1300 15w-40 engine oil and a Wix oil filter.
The transmission is speced to use Permatran tractor fluid. I have changed it twice in two years.
Thanks for the info. I changed my oil at 500. I haven't changed it since, it still looks good. I have added some permatran but never changed it. How much fluid does it take for a change?
   / GC17xx, coolant change #23
Where are the block drains can maybe you take a pic? I think I know where it's at I just want to be sure.
I think it was the square bolt to the right of the oil filter.
I don't understand, so that has to be drained as well, not just the radiator and overflow tank?
   / GC17xx, coolant change #26
Many engines will hold as much or more coolant then the radiator does.
   / GC17xx, coolant change #27
Removing that plug drains the coolant out of the block around the sleeves so you're getting a more thorough draining of the complete system
Gotcha, thx.
   / GC17xx, coolant change #30
My GC1725 manual specifies 40 to 60 percent ethylene or propylene glycol and to be changed every two years or 1000 hours
20-Ton Hydraulic Bottle Jack (A55852)
20-Ton Hydraulic...
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
2006 Suzuki GSX-R600 Motorcycle (A55853)
2006 Suzuki...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
No runner (A56859)
No runner (A56859)
