GC17xx, coolant change
   / GC17xx, coolant change #21
Addict, My MF manual says to use Massey Ferguson coolant but no specs are given. Also, the manual says change at 1000 hours. I change it a bit more often that that. I think that a quality 50/50 anti freeze is sufficient. Also, I change engine oil every year as well as the oil filter. I use Mobil Delvac 1300 15w-40 engine oil and a Wix oil filter.
The transmission is speced to use Permatran tractor fluid. I have changed it twice in two years.
Thanks for the info. I changed my oil at 500. I haven't changed it since, it still looks good. I have added some permatran but never changed it. How much fluid does it take for a change?
   / GC17xx, coolant change #23
Where are the block drains can maybe you take a pic? I think I know where it's at I just want to be sure.
I think it was the square bolt to the right of the oil filter.
I don't understand, so that has to be drained as well, not just the radiator and overflow tank?
   / GC17xx, coolant change #26
Many engines will hold as much or more coolant then the radiator does.
   / GC17xx, coolant change #27
Removing that plug drains the coolant out of the block around the sleeves so you're getting a more thorough draining of the complete system
Gotcha, thx.
   / GC17xx, coolant change #30
My GC1725 manual specifies 40 to 60 percent ethylene or propylene glycol and to be changed every two years or 1000 hours
2019 Genie GS-3232 32ft Electric Scissor Lift (A53421)
2019 Genie GS-3232...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2009 Honda odyssey (A55788)
2009 Honda odyssey...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
(5) 6" X 12# X 93" (1) 6" X 12# X 68.75" I BEAM (A57192)
(5) 6" X 12# X 93"...
TANK MANIFOLD (A55745)
