Mower Tires Crushed Flat for Shipment - Any Advise ????
   / Mower Tires Crushed Flat for Shipment - Any Advise ????
I don't know if I saw 90 degrees Fahrenheit more than once or twice a summer in Fletcher. Saw 40 below several times in the winter. That makes for hard tires :)
That's right - 85 degrees used to be a really hot day. Now we have days in a row in the 90's. I'm in Waterford. Between St. Jay and Littleton, NH.
gg
I just tube them, I've had too much trouble with small tires leaking air within a year or two if mounted tubeless anyway!
I hear what you are saying but to me it's a mixed bag. I've tried both ways. They are 2 ply tires and it doesn't take much for a flat sometimes. W/O tubes I can plug them or Slime them. Tubes I have to break them down to patch the tube which is not fun. You would think small rims would be easy but no. So I run tubeless until the tire gets real bad then tube it to get a little more life.
gg
   / Mower Tires Crushed Flat for Shipment - Any Advise ???? #13
What, Did you save $2 by buying them from Amazon ? All the ag stores have them round and black, probably same brand and quality. BTW: since there is very little 'rubber' in them traction is an issue. Get a real turf type tire send them back. I burned the 2 I had inherited. Funny how much 'tire' was left because it was all unburnable material. They still looked like tires !!!
???????????? I would have preferred to by them in a local store rather than Surplus Center (not Amazon) but the only 13 X 5.00-6 tires I could find any where except Surplus Center were complete wheell/tire assemblies. I would have been fine with that if I could find a 1" bore wheel for my heavy 1" axles but they are all 1/2 or 3/4 bores. If you know where some are with 1" bores or plain tires it would be helpful. Thanks !!
gg
   / Mower Tires Crushed Flat for Shipment - Any Advise ???? #15
gg
Are you anywhere near the Rabbit Hill Inn?
   / Mower Tires Crushed Flat for Shipment - Any Advise ???? #16
gg
you didn't look hard enough!. they are all over.. Tires - 13 x 5.-6 Tire Size - Free Shipping on Orders Over $99 at Summit Racing
The inn is down by the Conn River. I'm about 6 miles from there - mostly all up hill.
gg
   / Mower Tires Crushed Flat for Shipment - Any Advise ???? #19
If you have any Home Depot's in your area, at times theyhave good prices on such things. I probably buy 90% of my hand power tools there. Less than anyone else normally, but then they run some great salesat times too. https://www.homedepot.com/p/Hi-Run-13-in-x-5-00-in-6-4PR-SU12-Turf-II
While your waiting for them to reshape themselves, ask your buddies if they have, or know someone who has a bead seater tank. Amazon.com: TSI Cheetah Bead Seating Tool - 5 Gallon Capacity, Model# CH-5: Automotive They are the ticket for getting small tires like that out on the rim. I bought a used Cheetah brand (Supposed to be the best according to reviews) I found on FaceBook Marketplace for $40. It'll put that baby out on the rim in a split second. I was told by the guy I bought it off of, to remove the valve stem in the small tire I was trying to seat. It popped it out, but dropped back off the rim. I put the stem in, and started with a lower psi of 35, and it worked perfect.
Not sure how many tubeless tires you deal with, but I have more than several on diferent things around here. Usually over the winter, many will lose air through a non-perfect bead seat. Got some of this at a local auto parts store, https://www.oreillyauto.com/detail/...ffef52929/xtra-seal-bead-sealer/14101/4869951 broke the tires off the rim, and gave them a coat. Re-inflated them with the bead seater, and so far none that I have done have gone down, at least not like they did, probably due to it being the nylon valve cores.
   / Mower Tires Crushed Flat for Shipment - Any Advise ???? #20
You are right. I did not see them. I wonder if they are shipped flattened too ? I must have had a bad day. Doing another search I even found some 4 ply tires. Hard to explain what happens some times - Duh.
gg
they have just about any style in that size, and btw, carlisle is a very good brand, at least at one time made in USA.. they still might be.. Summit Racing is not going to sell flattened tires!. no-one would be buying from them if they did!.. btw, I have switched all my tires to tubed, less problems. with tubeless, I used to use a rope around the tie with a steel rod used to tighten up the rope, which expaned the tire, and gave a seal. it works like a tourniquet..
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
44052 (A55852)
44052 (A55852)
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
2006 Case 445 Skidsteer (A59814)
2006 Case 445...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
