Had a Ford 2n For many years, upgraded to a 1735M.
   / Had a Ford 2n For many years, upgraded to a 1735M. #11
Is it just me or does that metal look a bit off? More like pot metal that something solid.
Just typical cast iron break.
Is that pin just supported on the ear that broke or it also gets supported from the main rear casting?
The rear and seems to be built up from layers of castings bolted together. The pin was only supported by the part that broke, near as I can tell.
   / Had a Ford 2n For many years, upgraded to a 1735M. #13
If that's the only support for a pin that has to handle so many forces in so many different directions, that kinda a bad design from MF. That's a failure waiting to happen.
That pin needs to be supported on both ends with the lift arm in the middle.
Great, so I can look forward to it breaking again. :-(
   / Had a Ford 2n For many years, upgraded to a 1735M. #15
From the design, so obvious in your photo, I think you are absolutely correct!
You very likely...... "can look forward to it breaking again".
The dealer is going to fix it. No time table yet so I'm going to do what I can without it for now.
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
2014 Timpte Hopper Bottom (A56438)
2014 Timpte Hopper...
Caterpillar 906M (A53317)
Caterpillar 906M...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
KBH Tender Trailer (A56436)
KBH Tender Trailer...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
