Had a Ford 2n For many years, upgraded to a 1735M.
   / Had a Ford 2n For many years, upgraded to a 1735M. #11
Is it just me or does that metal look a bit off? More like pot metal that something solid.
Just typical cast iron break.
Is that pin just supported on the ear that broke or it also gets supported from the main rear casting?
The rear and seems to be built up from layers of castings bolted together. The pin was only supported by the part that broke, near as I can tell.
   / Had a Ford 2n For many years, upgraded to a 1735M. #13
If that's the only support for a pin that has to handle so many forces in so many different directions, that kinda a bad design from MF. That's a failure waiting to happen.
That pin needs to be supported on both ends with the lift arm in the middle.
Great, so I can look forward to it breaking again. :-(
   / Had a Ford 2n For many years, upgraded to a 1735M. #15
From the design, so obvious in your photo, I think you are absolutely correct!
You very likely...... "can look forward to it breaking again".
The dealer is going to fix it. No time table yet so I'm going to do what I can without it for now.
2009 Wilson Commander Hopper Bottom (A59814)
2009 Wilson...
2018 Kubota U17 (A53317)
2018 Kubota U17...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
*Selling at Royal Auction Tampa, FL Location* Year: 2008 Make: Freightliner Model: B2 Vehicle Type: (A59230)
*Selling at Royal...
