   / Harbor Freight Tools that don't suck #13,591
Have any of you bought the HF vacuum pump?
I bought one a couple years ago for some AC work. No problems with it.
   / Harbor Freight Tools that don't suck #13,595
Hey Thomas... good to hear from you. Haven't seen much posting by you lately.
Hiya Boss,
Thanks for noticing both my absence and return!
Yeah, what with work issues, deaths in the family, surgeries, and of course the current Black Swan issue; I hadn't been posting, or even reading a lot.
Just recently though, I got to catch up a bit on the reading because, except for emergencies [of which there were aplenty], we weren't seeing a ton of patients sometimes, but because it's a govment gig, signing in and posting wasn't possible.
Anyway, tonight after I had finally caught up on reading my continuing medical education, I needed something a little less pithy to peruse, and came here.
I have been enjoying several of the usual threads- gun times, wood and tractor times, your tool/workshop tips thread, and a few others, but that "you know you're getting old" thread keeps me scratching my heads.
I guess I just don't get all those references those old guys keep dropping...
:D
:cool::laughing:
Seriously though, it's good to see a lot of both familiar and new names here, and while a lot has changed, it also seems like a lot has stayed pretty much the same...
I do want to take a moment to wish all my old and new friends and
acquaintances here a happy, safe, and healthy rest of the year and beyond, because if I learned one thing over the past year or so, you never know when or if you'll see or be in touch with any given person ever again.
In the words of one of my favorite books- Man proposes- GOD disposes..
You're all in my prayers.
   / Harbor Freight Tools that don't suck #13,596
What's your limit at HF?
I've only bought a few things over $50 and maybe just a couple over $100. By far the most have been under $25
   / Harbor Freight Tools that don't suck #13,598
The one expensive thing I've bought there was their previous version of the 6hp garden chipper-shredder. Big disappointment. In contrast to the description its useless to shred any pruning debris that is too large to cut with pruning shears, so about 3/4 inch, and you have to feed that slowly so it doesn't gag requiring disassembly. The side opening will take anything to broomstick diameter but with vibration so severe it will give you carpal tunnel syndrome to feed it in. Slowly. Low oil sensor so delicate that you need to level the machine with a carpenter's level and then much frustration as it vibrates, gets imperceptibly off vertical, and kills the engine. Bottom discharge, you have to move the machine to pick up its discharge.
This thing must be an ignorant replica of a machine designed to shred fall leaves for bagging - its not really a pruning shredder at all. $350+ wasted.
But in contrast to that, I can't think of anything expensive not worth what it cost. The most recent over $100 purchase was the 1 ton foldable shop crane, it works as intended.
   / Harbor Freight Tools that don't suck #13,599
Most of the things I buy from Harbor Freight have ended up being under $100. IT was only a couple years ago that we got a store in our area, and I like to see more expensive things before I buy.
Things that exceeded $100 that I can recall:
All of the above were on sale when I bought them. All have worked well.
   / Harbor Freight Tools that don't suck #13,600
Only difference I can ascertain in the 3500 pound winches is the end bell freespool knob.
I see HF has another recall on the jackstands. This time the 'improved' model is faulty. It's a leg weld this time.
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
(APPROX. 20) 4' X...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2019 International DuraStar 4300 24FT Box Truck (A56858)
2019 International...
PALLET OF MISC HOSE & PIPE INSULATION (A58374)
PALLET OF MISC...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
