dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,619
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
Deere uses ORFS O-ring Face Seal style fittings on there equipment. Yes these are usually more expensive than NPT or JIC but are also almost zero leak and getting more common.
Most loader valves will have SAE O-ring boss ports or BSPP threaded ports. Fittings to go from SAE to ORFS are pretty common.
I re-hosed the loader on a JD4300 a while back, and I saved a bunch by buying ORFS-to-JIC adapters, then JIC hoses. NPT connections are lousy in the hydraulics world.
As for an FEL valve, SurplusCenter currently has a nice looking Chief joystick FEL valve with float, but no PB sleeve. $189 + ship. The valve seems to have a PB function, but you need that sleeve.
