sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 15,721
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Easy way to get rid of tree stumps in the yard. Just cut it flatter-than-flat to the ground, keep saw out of the dirt and coat stump with Roundup to kill it. Paint stump black so it's not so obvious to the eye and a year later burn it with a hardwood fire and a leaf blower. Low to the ground means I can mow over it with my 7' pull type mower right now.
Here are some pics. The trunk piece shows that I cut a kerf around the outside first and then kept nibbling till I got to the center. Need sharp saw.
Below is a stump cut last year that will be burned when or if it ever rains again.
When I burn, I start the fire and push coals to the outside of the stump. Hit the center with a leafblower and it burns plenty deep into the ground. No backhoe mess, just blow cinders and ash out, fill with dirt and seed. Close enough for gov't work.
These are from similar efforts this spring. The second pic was a 16" or bigger soft maple.
