Big Barn’s Retirement Farm Shop
   / Big Barn’s Retirement Farm Shop #2,761
When buying valve stems for this or gas cans just make sure to get the good ones. Like the ones with the tightening nut because they don't break down from chemicals or gas. Ozone eats the China rubber ones pretty quick too.
( valve core removed for gas can vent)
   / Big Barn’s Retirement Farm Shop #2,762
Re: Big Barn痴 Retirement Farm Shop
I lubed it with Bead Sealer. Don't think that's necessary. Probly made it install easier.
How much air pressure did your's take before the relief valve opened? I chickened out at 40 psi.
My valve measured 38/64ths so I drilled a 9/16 hole which I thought was a bit undersized but turned out to be a smidgen to big so I sealed it with silicone. A 1/2" hole may have been better.
Cool wheels, bigtiller! Golf bag cart?
   / Big Barn’s Retirement Farm Shop #2,764
I didn't even have a shed to work in until I was 28 years old. Got my first shop with concrete floor when I was 44 years old.
46 or 47 here. Remember doing so much work on my gravel driveway, underneath the vehicle, at night, while it was raining. Because that's what I had to do.
   / Big Barn’s Retirement Farm Shop #2,765
I've got several new, rubber valve stems already but decided to swing by AutoZone tomorrow for these. $4.99 for the pair.
   / Big Barn’s Retirement Farm Shop #2,766
That is whats left of a 3-way battery powered 4 gallon backpack sprayer with wheels. The sprayer turned out to be junk but the cart was sturdy so I remodeled it and tied on this 2 gallon sprayer.
Walking around the buildings spraying with it is a whole lot easier with it on wheels.
   / Big Barn’s Retirement Farm Shop #2,767
There are two different sizes of valve stems. So be careful which one you drill a hole for. I just measure with a calipers and drill the hole a size or two smaller. It sure takes the drudgery out of spraying with a small tank.
Perfect answer. I don't remember what size the bit was.
   / Big Barn’s Retirement Farm Shop #2,768
View attachment 664420View attachment 664419
I hadn't ever checked the pressure. So I tested it. Best I can tell 35psi.
   / Big Barn’s Retirement Farm Shop #2,769
I didn't want to go in debt to have a shop so waited until I could pay cash. My youngest Son was 17
If doing it over I would borrow the money and build it for my boys to grow up in. Could have benefited from many, many hours of Father/Son time together.
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
2012 International 4300 Reefer Truck (A57024)
2012 International...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
White Metal Roof Panels (A55758)
White Metal Roof...
