Price Check Used B26 TLB or New Kioti CK3510
   / Used B26 TLB or New Kioti CK3510
The Kubota is a HD commercial grade offering. Only 275 hours of residential use? I bet 98% of them listed have been worked hard and put away wet in a commercial or rental environment.
What is the Kioti going to be worth in 5 years and what is the Kubota going to be worth?
Good thoughts John. Not sure how much resale value Kioti carries versus Kubota. Im sure Kubota is much higher
   / Used B26 TLB or New Kioti CK3510 #12
Mat, thanks for the input. It's almost like new. It hasn't been treated rough at all. Was purchased new by the owner and never used commercially.
I see the point about a new one being 38000. But a 10 year old unit for 24000? I feel like it should be around 21000
Depending on the dealer, the B26 was offered with a range of options. Does it have a spare backhoe bucket? Does it have the 3pt kit? Accessory hydraulic outlets? An upgraded lighting kit? Anything else? A few of those would easily make up the price difference and are an example of the value of buying low hr. used.
In tractors 10 years of being stored out of the weather are nothing. How it is used and maintained is everything. Tractors don't really have a model year like cars do. Tractors go by serial number. Typically a model is made in a factory run and then warehoused until sold.
   / Used B26 TLB or New Kioti CK3510 #13
You can feel that for months and never find one that nice at any price.
You are seeing that right now. Also Kubota is the ONLY player in the industrial grade compact TLB space.
Thanks Rick, So a B26 vs a L2501? Are yall saying the B26 is more of a commercial machine vs some of the other Kubota models? This man only used this for cleaning up a few ditches and moving some rocks from a slide behind his house. I doubt it has ever been pushed to any kind of limits
   / Used B26 TLB or New Kioti CK3510 #17
Yes. exactly. Kubota's TLBs are not a true commercial machine, but tending that way and more heavily built throughout. That is what makes them more expensive than tractors with add-on loaders and backhoes, and the higher price is why you see fewer TLBs than Tractors. On the TLB, the backhoe is standard and the 3pt hitch is an attachment. On tractors it's the other way around.
Sounds like the guy knew what he was doing. His work seems more landscaping than growing crops or gardening, so he got the right tool for the work you describe even if it did cost more.
Does his backhoe have the hydraulic thumb option? If so, there's the price difference right there.
   / Used B26 TLB or New Kioti CK3510 #18
I have been working at a Kubota dealer since we moved south in Sept 2017. We have sold several hundred B and L series tractors in that time and one each of the TLB models. We have worked on a small handful of others. They just are not that common. Same story when I was up in NY.
   / Used B26 TLB or New Kioti CK3510 #19
Been considering buying a new tractor. Mostly been looking at Kubota or Kioti. Done a lot of research and mostly settled on buying a new Kioti.
Had a friend list their 2010 Kubota B26 TLB (hydrostat) for sale. Only 275hrs, has the ROPS roof/cover. Drove it and sounds and runs great. They want 24000, which seems a little high to me after checking tractorhouse and equipmenttrader.
So, if i cant talk them down, is 24000 a fair price? Any suggestions on getting them down to around 20000? They seemed pretty firm on it...
I can get a 2020 Kioti CK3510 for 28000.
Yes, im aware of the difference in HP. But a kubota with no warranty vs a new tractor for 4000 more with a 6 year warranty?
Thoughts? Suggestions? Opinions? Thanks!
Can you see yourself using a backhoe?
That's easily worth the difference.
And the TLB is a more rugged machine.
I got them down to 23800. Im checking with my local bank to see what kind of financing options I have. Looks like a 5 year loan at around 4.99 percent. Any experts on here with better options? I dont have that kind of cash to pay right now....
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
KSI Conveyor (A53473)
Engel 20' Boat (A50121)
Engel 20' Boat...
