Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #14,821
I couldn't find any fat wood but did find plenty of skinny wood, this stuff has been sitting for 6 years. I got it under the cover just before the down pour, probably cut it up this weekend. Then after I soak it in gas for two weeks should be the best starting skinny wood around.
   / Tractors and wood! Show your pics #14,822
Oh no.. soak it in a gas diesel mix, wont burn up so fast! Just like starting a burn pile or controlled burn...
Looks like you should have plenty though!
   / Tractors and wood! Show your pics #14,823
For fire starter I simply fill a 5 gallon bucket with planer chips and pour in pint or so of diesel fuel. Put a lid on the bucket and in a short while the chips will absorb the fuel making a non explosive fire starter..
A small scoop will get a good fire started in no time. Been using that method for 40 years.
B. John
   / Tractors and wood! Show your pics #14,824
B. John
That seems like a better option but not many have planer chips. Wonder if it would work with sawdust?
   / Tractors and wood! Show your pics #14,825
My daughter gave me a bag of kiln dried hickory cubes for my birthday,,
that stuff burns like diesel fuel,,
I think most of us have not experienced burning dry wood.
I went and found a 8 inch hickory tree that was blown down and cut up two years ago,,
I figured I would make my own hickory fire cubes.
Then, I cut 2 inch disks off the log, as I cut them, they dropped into a 55 gallon plastic drum.
I put the drum, with the disks in the shed, with a piece of metal roofing sitting loosely on top.
The next morning, water was dripping from the underside of the metal roofing,
There was SO MUCH water coming out of that wood, and it had been cut for 2 years,,
I am amazed how much water is in that downed wood,,
I should cut some more, weigh it, then let it set, and weigh it again, just to see what weight it really looses.
Oh, yea, my hickory blocks burn slower than the kiln dried ones,, so I know they are not as dry,, yet,,,
   / Tractors and wood! Show your pics #14,826
I've used planer chips and sawdust with diesel and used oil...
I prefer "what ever I have" and use used motor oil, as I have plenty of it around and it works just fine....
SR
   / Tractors and wood! Show your pics #14,827
I'll just stick with my DELUX fatwood and project cutoffs!!
   / Tractors and wood! Show your pics #14,828
Works fine with sawdust. However, I don't have enough sawdust so I buy a bale of wood chips (bedding) at Tractor Supply. I don't mix in diesel, I pour in the used oil from oil changes. Works like a charm in my shop. I use traditional kindling in the house because my wife would freak out if I brought the chips and oil inside.
   / Tractors and wood! Show your pics #14,829
WHAT??? Not have planer chips?? What are you talking about not having planer chips!!:D
   / Tractors and wood! Show your pics #14,830
Re fire starter. Sawdust will sorta work but is not as aggressive as shavings from a planner, jointer, shaper, or good ole hand plane.
The chips from a well sharpened chain saw if left to dry in the sun and soaked in diesel and yes used motor oil will work too.
Although we graduated from wood heat to geothermal in the house 12 years ago I still burn wood in my shop and in my opinion, there’s nothing better than to treck out to the shop on a blustery day with my K9 buddy and depending on the time of day, a cup of coffee or an adult beverage, pull up the comfy ole desk chair next to the stove, lean back and contemplate my next project.
It’s the ultimate in senior safe space.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2017 ISUZU NPR 16FT BOX TRUCK (A54607)
2017 ISUZU NPR...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2025 GREAT DANE FLP-0024-00053 53FT SPREAD AXLE FLATBED (A54607)
2025 GREAT DANE...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
