4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 18,509
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
The issue is with the generator. The engine in a Prius is a relatively large, fuel injected, water cooled engine optimized for fuel efficiency which costs several thousand dollars new. The engine in a generator is a small, carbureted, air-cooled engine optimized for price which costs a few hundred dollars. From the start the generator engine will be less efficient.
The EU2000 has two other disadvantages on top of that. The first is that it's a low power generator. Bigger engines of the same type tend to be more fuel efficient and the 100 cc engine simply won't be as efficient as something bigger. Then there's the fact that the EU2000 is an inverter generator. Inverter generators are a great optimization for variable, often low, loads. It comes at an efficiency cost though. At full power an inverter will be less efficient than a conventional generator of the same size.
The EU2000 will get the job done, but for charging an EV a bigger, standard generator will give better MPG.
At least one person did the test with a good diesel generator and found a mileage of 4.2 l/100KM, or about 56 US MPG, but they don't say how they accounted for slow charging as the EV reaches 100%.
The couple hundred dollar engine was never an option. A Kubota diesel would do a fine job running a generator.
