4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 18,451
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
Ut the one that insist pressure is not pressure and that a larger diameter cylinder reduces pressure. So by that you are saying a bigger cylinder produces less force.
And yet you insist I am an idiot! While exhibiting your foolishness! Why? Because you missed you have been feed the rope and hung yourself!
You fell hard!
And I’m not suggesting a bigger cylinder produces less force. I’m suggesting exactly the opposite. If it takes your loader 2500 psi to lift a ton with the current cylinders and you changed the cylinders to bigger cylinders how much pressure would it take to lift the same ton load? Certainly not the same 2500 psi. Since the bigger cylinders are stronger they require less pressure to do the same work. I never called you an idiot but it’s starting to look that way.
