DYI fume extractor ideas
   / DYI fume extractor ideas #1
GeneV
Elite Member
Lake County, IL
Bradley 48" stander MF GC1710
Guys, who built their own welding fume extractor? I put this one together on the fly yesterday, using a wet/dry vac. It works ok, but I'm not super thrilled with it. Here's it here:
I was thinking one of those inline duct fans with ductwork could work. The 6" ones move 240 cfm. Would that be enough for a fairly short run of duct exhausting out the window. Would even a 4" 100cfm duct fan work here?
   / DYI fume extractor ideas #2
Look at portable dust collectors the smallest will move about 500 cm, remove the dust bag to reduce the fire hazard and replace it with a length of 4 - 6" duct.
   / DYI fume extractor ideas #3
Monkey Arms - At work we bought one to try and then bought two more. We built a sort of flexible jib to mount them and used flex duct at the joints. With a homebrew swivel at the wall, the duct drops into an inline fan and exhausts our of the sidewall. My guess is they cover at least a 20' radius. I can get pics and fan data if anyone's interested.
Fume Extraction - Welding & Grinding - Monkey Industrial Supply
No no guys, on the cheap, gotta be on the cheap. I don't even wanna go past 100 bux on this, I don't think I should have to for my amateur butt, doing amateur welding.
   / DYI fume extractor ideas #5
I'm with you Gene, Harbor Freight or Amazon are likely vendors for a value fan/duct.
A variable speed fan would be nice to regulate the flow of CFM.
KC
   / DYI fume extractor ideas #6
How much risk is there of you sucking up sparks or hot bits of metal with this fume extractor?
If there is, I might see about running through a bucket of water to cool off any such bits of metal.
Could also use that to reduce the nasties in the fumes going out.
If that little Shop-Vac wasn't enough, I would get a bigger one that has an actual 2-in hose and use that. I have one made by Rigid and it is amazingly quiet.
If you are going to mostly welding at the table like that, you could put a piece of 2-in metal conduit together with a 90 and a 45 to connect to your filter bucket.
Aaron Z
   / DYI fume extractor ideas #7
Hey Gene, thanks for starting this thread. Been wanting to do something similar on the cheap. Have been looking for a used fume extractor but they ain't cheap. I think I want the extractor hose to be metal and something inline to knock down the sparks before entering the fan, and of course exhaust to the outside. Looking forward to DIY ideas here.
BTW...I have the same HF welding table. I really like how portable it is and I use for plasma cutting as well.
KC
Those duct fans are pretty cheap, the 6" one is around $25 at home depot. With that and some rigid and flexible ducts, it would be a under $50 build. Variable speed would be real nice, yeh.
Aaron Z
Thanks man, sparks are a good point! Well wet/dry vac, I guess I could just suck some water into it, right? Yeh, this vacuum is loud! Would love a quieter one. Also, it doesn't seem powerful enough, I want it to suck up more of the fumes. Another problem is the sump pump hose I'm using to exhaust out the window makes a whistling racket. I'm thinking a smooth long hose would be quieter if I stayed on this route of using a shop vac.
It is a great table, and HF's price for it is great as well, right?!!
I'm in a tricky position here in regards to cfm's. On the one hand, needs to be powerful enough to get the smoke/fumes out of the shop. But then, not too powerful so that it's sucking out all my heat in the winter, or my breathing air for that matter. This is a longish 1-car garage I'm working it, heating it with electric space heaters in the winter.
Here's a quick vid I made of my shop vac extractomajigger, so you could see how it's working or not working. And yeh, looking at my vid, I think the concern about sparks is legit guys, thanks for pointing that out.
2002 Freightliner FL70 Elgin Street Sweeper Truck (A51692)
2002 Freightliner...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
New Land Honor Skidloader Trailer Mover (A50774)
New Land Honor...
Poly Round Bale Ring (A50515)
Poly Round Bale...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
