DYI fume extractor ideas
   / DYI fume extractor ideas #21
Shop vac is high suction, low flow. Duct fan is the opposite. That is what you need for this application. Too much draw could adversely affect the shielding of the puddle, but it is more likely that you just aren't getting much effect from the vac given the low flow and distance to weld.
   / DYI fume extractor ideas #22
Why not adapt a range hood from the box stores? This would give you two speed fan and lighting to boot!
   / DYI fume extractor ideas #24
   / DYI fume extractor ideas #25
Thanks Big Barn for finding what I was envisioning! Only difference i would do is to make the sides of hood extend a bit more or flare outward to help capture the smoke. The grease filter would help with the sparks, just not sure about the bulb covers.
   / DYI fume extractor ideas #26
I was thinking the same thing about the usefulness of the grease filters as spark arrestors. Probably would be nice to upgrade the CFM of the fan to match industrial fume extractor numbers.
Dstig1, thanks for the info, I'm gonna research that a little more about suction vs flow.
The range hood seems like a real good idea, but wouldn't work for me coz of my low ceiling.
   / DYI fume extractor ideas #28
   / DYI fume extractor ideas #30
2005 Mack Vision Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Mack Vision...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
2019 KENWORTH T680 SLEEPER TRUCK (A52141)
2019 KENWORTH T680...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
