T330 Front Mounted Hydraulic Snowblower Possible?
   / T330 Front Mounted Hydraulic Snowblower Possible?
   / T330 Front Mounted Hydraulic Snowblower Possible? #12
Yea this is seeming like something I just need to pass on. I think I'll get in over my head if I start trying to make it work. Thanks all!
it's still something worth buying fixing up, and reselling, the one's in the link cost $13,000+ so think about that..
   / T330 Front Mounted Hydraulic Snowblower Possible? #13
I have a front hydraulic blower, and no it wont run on tractor hydraulics. Mine has a separate 25 gallon hydraulic tank and a 15gpm, 3,000 psi pto pump to power it thru a set of 1” hoses.
Interesting.
10gpm at 3000psi isn't that far off.
I still think I'm just going to pass on it. Thanks for all the info.
   / T330 Front Mounted Hydraulic Snowblower Possible? #15
Interesting.
It's actually a 50% difference with a separate 25 gal container acting as a heat sink with larger hoses. A system separate of the tractor's system made to move a few cylinders.
   / T330 Front Mounted Hydraulic Snowblower Possible? #16
exactly. Running all that hot hydraulic fluid thru tractor would damage tractor. My rear tank actually has steam rising off of it when in usr.
Thanks all , I appreciate the input.
Cheers
   / T330 Front Mounted Hydraulic Snowblower Possible? #18
Interesting.
Keep in mind that 10gpm is maximum flow including steering pump. Your tractor actually has 6.5gpm. I am pretty sure you can't do 2 functions at once with your FEL. I know I couldn't with a 474 with probably the same pump.
   / T330 Front Mounted Hydraulic Snowblower Possible? #19
Because we are talking snow blowers ambiemt temps are going to be low. Wonder if that will help the situation.
This is why some tractors like the MX6060 still have a mid pto. To be able to run this kind of setups.
   / T330 Front Mounted Hydraulic Snowblower Possible? #20
i could have added a mid pto to mine and run a front snowblower that installs on a subframe. the reason i didnt go that route was i needed to lift my blower up to 6' in the air to clear the building shed off. you cant do that on a subframe unit. plus, with a subframe i cant just swap out between plow and blower like i can do now. its literally a 2 minute swap.
UNUSED LANDHERO LDH-GAC40Y AIR COMPRESSOR (A57193)
UNUSED LANDHERO...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
UNUSED FUTURE XJ7T-7T HYD THUMB CLAMP (A57193)
UNUSED FUTURE...
2017 Volkswagen Passat Sedan (A55853)
2017 Volkswagen...
200729 (A57192)
200729 (A57192)
