T330 Front Mounted Hydraulic Snowblower Possible?
   / T330 Front Mounted Hydraulic Snowblower Possible?
   / T330 Front Mounted Hydraulic Snowblower Possible? #12
Yea this is seeming like something I just need to pass on. I think I'll get in over my head if I start trying to make it work. Thanks all!
it's still something worth buying fixing up, and reselling, the one's in the link cost $13,000+ so think about that..
   / T330 Front Mounted Hydraulic Snowblower Possible? #13
I have a front hydraulic blower, and no it wont run on tractor hydraulics. Mine has a separate 25 gallon hydraulic tank and a 15gpm, 3,000 psi pto pump to power it thru a set of 1” hoses.
Interesting.
10gpm at 3000psi isn't that far off.
I still think I'm just going to pass on it. Thanks for all the info.
   / T330 Front Mounted Hydraulic Snowblower Possible? #15
Interesting.
It's actually a 50% difference with a separate 25 gal container acting as a heat sink with larger hoses. A system separate of the tractor's system made to move a few cylinders.
   / T330 Front Mounted Hydraulic Snowblower Possible? #16
exactly. Running all that hot hydraulic fluid thru tractor would damage tractor. My rear tank actually has steam rising off of it when in usr.
Thanks all , I appreciate the input.
Cheers
   / T330 Front Mounted Hydraulic Snowblower Possible? #18
Interesting.
Keep in mind that 10gpm is maximum flow including steering pump. Your tractor actually has 6.5gpm. I am pretty sure you can't do 2 functions at once with your FEL. I know I couldn't with a 474 with probably the same pump.
   / T330 Front Mounted Hydraulic Snowblower Possible? #19
Because we are talking snow blowers ambiemt temps are going to be low. Wonder if that will help the situation.
This is why some tractors like the MX6060 still have a mid pto. To be able to run this kind of setups.
   / T330 Front Mounted Hydraulic Snowblower Possible? #20
i could have added a mid pto to mine and run a front snowblower that installs on a subframe. the reason i didnt go that route was i needed to lift my blower up to 6' in the air to clear the building shed off. you cant do that on a subframe unit. plus, with a subframe i cant just swap out between plow and blower like i can do now. its literally a 2 minute swap.
2006 Ford F-650 Terex Hi-Ranger TL37P 37ft. Bucket Truck (A55852)
2006 Ford F-650...
2013 International DuraStar 4300 Altec L42A 42FT Bucket Truck (A55852)
2013 International...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
CATERPILLAR 312EL EXVACTOR (A52707)
CATERPILLAR 312EL...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
