Dmacleo
- Joined
- Sep 11, 2020
- Messages
- 1,931
- Location
- Etna, Maine
- Tractor
- 2010 MF GC2400 Owner, 2012 MF1532 User
thanks
Surplus Center S41-2
should fit if I have read everything right
edit: those purchased, 1/4 hose and single 5k psi liquid filled gauge ordered. gauge set for plows/bobcat will be sep order under company when needed.
many thanks to all involved here, very good info.
now wait for shipping and then test pressures. flow rate seems ok, empty from full down to full up at 2600rpm is, by mental count, 4.1 seconds which is VERY close to manufacture spec of 3.7.
just initial breakout when bucket is in loam/compost pile is issue. tilt and reverse few inches helps but suspect (by looking at adjust screw) this has never been checked and I may be on low side
