DYI fume extractor ideas
   / DYI fume extractor ideas #112
Gene, your in business to burn some rod now, good job!
KC
   / DYI fume extractor ideas #113
Thanks Gene. Really great :thumbsup:
gg
Thanks guys! I'm gonna change that flexible duct to rigid, I don't think it's air tight enough currently. Also, I'm gonna put a hood on the end of it to catch more fumes.
   / DYI fume extractor ideas #115
Ok well thanks for the inspiration. My fume extractor just jumped a few spots on the to do list. Last time I plasma cut in my shop, my A/C drain line got full of rusty water. Made me think about what I'm breathing. Been cutting & welding outside since. Tired of that. And the solution is apparently very easy and cheap. Thanks!
   / DYI fume extractor ideas #116
Looks like it works decently. Would be nice to get it a bit closer to your work. I also see you can't swing it around, which would be handy, but the flex duct can make up for some of that. Nice work!
And unless you enjoy sunburn, I'd get some long sleeves...
Man, awesome! :)
Yeh if I was welding-welding I'd wear sleeves, this was just running a bead right fast to test out the fan. Been there / done that with the arc sunburn, yup.
I got a hood now. Built it with 2 reducers, 10" to 8" and 8" to 6". I welded for a few hrs today, just messing around, practicing.
Extractor worked great!
   / DYI fume extractor ideas #120
Gene, can you position the 'hood' around a bit? And does it stay put?
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
Brandt Grain Vac - Mod. 5000EX (A59814)
Brandt Grain Vac -...
CAT 336E (A58214)
CAT 336E (A58214)
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2023 BOBCAT E50 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E50...
