Weld broken hydraulic cylinder stanchion rod
   / Weld broken hydraulic cylinder stanchion rod #21
by DC reverse do you mean DC electrode positive? the terminology really makes me nuts. i generally leave my machine on DC electrode positive, and i am almost certain that thats the same as reverse polarity.
   / Weld broken hydraulic cylinder stanchion rod #22
Just saw you have a JohnDeere 310D, the stabilizer hyd rod will be 50mm, if you buy a piece of chrome stock to make a new one specify 50mm chromed plated induction hardened material.
That should be real easy to find in Costa Rica ????
I ended up having the local machine shop fix it. I went in there to ask them if I could weld it and they said it won't work don't try. My guru mechanic, the machinist, and one of the old school operators around here all told me the same thing. It'll break at the heat affected zone, and if it does it inside the cylinder it'll cause some very expensive problems.
The machinist knew where to get chromed rod so he installed a new piece for $250. Kind of an expensive repair but not that bad.
Thanks everyone for the advice.
UNUSED RYOBI 80V HP BRUSHLESS ELECTRIC PUSH MOWER (A51248)
UNUSED RYOBI 80V...
2018 International DuraStar 4300 Dump Truck, VIN # 1HTMMMMNXJH633369 (A51572)
2018 International...
2023 LMC M40018 LOT NUMBER 176 (A53084)
2023 LMC M40018...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
UNUSED FUTURE XJ3T 3TON 30" HYD THUMB CLAMP (A51248)
UNUSED FUTURE XJ3T...
2011 Toyota RAV4 4x4 SUV (A51694)
2011 Toyota RAV4...
