Well pressure tank oddity
   / Well pressure tank oddity #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
Our tank has a 40/60 switch and a few years ago I recall verifying those pressures on the gauge. I happened to notice the other day that pressure is dropping to 35psi then being pumped back up to 65psi. So something is off. Could this be a sign of a leaking bladder, or maybe the switch is going bad? The switch clicks on and off like usual. I don't detect any oddness other than the change in pressure.
Also, tank and switch are about 7.5 years old.
   / Well pressure tank oddity #3
My first thought was a ruptured bladder. I just go with an old style tank and fill it once a year.
   / Well pressure tank oddity #4
Because your low pressure is lower and your high pressure is higher, I don't think it is your tank.
Pressure switches do wear out over time, but two things to try;
1) try adjusting the upper and lower court off/cut in via the adjustment screws/nuts. Sometimes they do slip with time.
2) if #1 doesn't, work, try cleaning out the pipe to the pressure switch. They often get corroded up with scale, rust, and/or sand.
If that doesn't fix it, I would replace the switch. Generally, they are inexpensive. FWIW: I have hard water and replace them about every six years or so. YMMV...
All the best,
Peter
   / Well pressure tank oddity #5
I had odd water pressure issues a couple years ago. It was due to the small pipe leading to the pressure switch being clogged. I cleaned that, put on a new switch and issue solved. I'm curious how long it's going to last before it starts showing signs again. Just something to check if you decide to replace the switch.
   / Well pressure tank oddity #6
You should be able to adjust your pressure switch, plenty of youtube videos, if it wont adjust, replace switch. Before I would do anything, I would make sure the pressure gauge is valid. They are not that expensive at the big box stores.
Start cheap and work your way up.:laughing:
   / Well pressure tank oddity #7
I had the same problem, but I replaced the rust-clogged 1/4 inch iron pipe with brass.
Bruce
   / Well pressure tank oddity #8
All the best,
Peter
*2 first and always. Simplest, quickest and most likely. I have to do mine about every 5 years. Probably not needed but I put in a new pressure switch at the same time, the cost is surprisingly low.
   / Well pressure tank oddity #9
You don't say what type of well etc...if there is a foot valve or a check valve on the suction side it could possibly be leaking the pressure down...if there is a cut off valve on that line try cutting it off and see...
   / Well pressure tank oddity #10
Just thought I might add this. I have been meaning to add a second pressure switch with a higher LOW cutout, as I find my water softener doesn't work reliably at the lower limits of my current switch. So switch to the higher one for the softener, then switch back.
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53472)
2023 New Holland...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
