any toro groundsmaster fans on here?
   / any toro groundsmaster fans on here? #911
Answer, there is only one way to find out if it will work. Do it. :)
   / any toro groundsmaster fans on here? #912
Pulled the new to me 322d with Olathe 82 seeder into the shop for its initial service. Will change fluids, filters, belts, and adjust everything. Looks to be in good shape. This is my first two wheel drive, so learning a bit about that difference.
   / any toro groundsmaster fans on here? #913
https://www.toro.com/getpub/19720
Discovered today that my model 82 seeder can also be used as a powered dethatcher. I attached the manual link, hopefully it works.
Briefly looked at the seeder yesterday. A few of the seed drop tubes were clogged with dirt, and it looks like someone welded the seed flow adjustment handle in place, so it is no longer adjustable. Will see if I can fix that.
   / any toro groundsmaster fans on here? #914
:thumbsup: Interesting.
Yep, the link for the manual worked.
Good luck getting it restored and keep us posted.
   / any toro groundsmaster fans on here? #915
Wanted to post some pics of often overlooked lubrication points on the pto system. None of these areas have a zerk fitting, but do require lube or they will wear out. A rattle can type lube with a long straw works best for me. What I use is white lithium, but may try a motorcycle chain lubricant next as it is sticky and will stay put.
   / any toro groundsmaster fans on here? #916
Finally got to use the 82 seeder today. The 322 was in really good shape. Did a full full fluid and filter change, needed one new tire, a few bushings for the pto fork, and a new roller for the neutral detent. Thing is a beast.
The seeder needed a new roller chain, lots of rusted pivots freed up, a general grease job, and all the seed tubes cleaned out.
Has a seed adjustment flow handle, and a depth adjustment on the front wheel.
Inside of the seed hopper. There is a rotating agitator inside that dispenses the seed, but only when the coulters are on the ground and rotating underneath.
   / any toro groundsmaster fans on here? #917
The seed adjustment chart for the flow control handle.
Did a test on the asphalt with the flow handle set at 5. It gives a nice even disbursement, but was a bit heavy, so I dropped the handle down to 4.
The business end. The front tines are pto driven and dethatch, or scarify the soil depending how deep the front wheel adjustment is set. The second row of coulters roll across the ground covering the seed as they go. They are attached to a single shaft and drive the agitation mechanisms in the hopper via a chain and sprocket. The seed tubes discharge seed right next to the coulters. The back side of the coulters have a wiping arm to keep dirt from building up on them.
Was very impressed with the seeder. I put down 50 lbs of seed today on various parts of the property. Looking forward to using it again in the Spring.
   / any toro groundsmaster fans on here? #918
blue TU.gif interesting.
   / any toro groundsmaster fans on here? #919
Having trouble with thevwater punp on my Toro 223D Groundsmaster. Model 30223. Serial. Before 69999. I ordered pump number 67-4380. It shows the same water pump for all the serial numbers.
The hub on the pump is the same size as the pulley 3.25 O.D. I have. So the pulley will not fit over top as it is supposed to. It shows all pulley numbers to be 67-4360.
How do I find out the measurements on pulley 67-4360?
I bought this about year 2000. Things May have been swapped out before I got it
   / any toro groundsmaster fans on here? #920
I could not figure out how to edit on the tablet.
My belt 67-4410 is also too short
Toro 5700D Multi Pro Sprayer (A58216)
Toro 5700D Multi...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
CFG Industry H12R Mini Excavator (A57149)
CFG Industry H12R...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
New/Unused Pallet of Ground Protection Mats (A57454)
New/Unused Pallet...
