Grumpycat
Super Member
Be careful with the use of lighter oils. They do not protect as well and they are used for fuel mileage in cars. Not a good reason for switching in your heavy equipment. Cars are trying to meet cafe requirements.
That is not true. A lot was learned about how plain bearings and lubrication works in the 1970's and 1980's. A seminal article was published in the SAE journal co-authored by GM and Ford engineers. They found more significant forces holding the bearing surfaces apart than just viscosity. That they could use lighter oils every bit as well or better than heavier. However changes were necessary to the bearing design which rendered the heavier (then 10W-40 was the industry standard) unsuitable.
In other words, you don't know better than the engine manufacturer. Use of a heavier oil in an engine designed for 0W-20 will do harm. Just as use of a lighter oil in an engine designed for heavier oil will do harm.
Quite frankly I don't see engines dying on the sides of the road due to lighter motor oil as was predicted by armchair mechanics.
